Instance Custom Nodes Actions
https://api.losant.com/instances/INSTANCE_ID/nodes
Below are the various requests that can be performed against the Instance Custom Nodes resource, as well as the expected parameters and the potential responses.
Returns the Custom Nodes for an instance
GET https://api.losant.com/instances/INSTANCE_ID/nodes
all.Instance, all.Instance.read, all.User, all.User.read, instanceCustomNodes.*, or instanceCustomNodes.get.
| INSTANCE_ID | ID associated with the instance | 575ec7417ae143cd83dc4a96 |
| sortField | N | Field to sort the results by. Accepted values are: name, id, creationDate, lastUpdated | name | sortField=name |
| filterField | N | Field to filter the results by. Blank or not provided means no filtering. Accepted values are: name | filterField=key | |
| filter | N | Filter to apply against the filtered field. Supports globbing. Blank or not provided means no filtering. | filter=my*node |
| 200 | Instance Custom Nodes | Collection of Custom Nodes |
Create a new Custom Node for an instance
POST https://api.losant.com/instances/INSTANCE_ID/nodes
all.Instance, all.User, instanceCustomNodes.*, or instanceCustomNodes.post.
The body of the request should be serialized JSON that validates against the Instance Custom Node Post schema. For example, the following would be a valid body for this request:
  "name": "My New Instance Custom Node",
  "description": "Description of my new instance custom node",
  "triggers": [
      "type": "customNodeStart"
  "nodes": [
      "type": "CustomNodeCapNode"
    -d '{"name":"My New Instance Custom Node","description":"Description of my new instance custom node","triggers":[{"type":"customNodeStart"}],"nodes":[{"type":"CustomNodeCapNode"}]}' \
| 201 | Instance Custom Node | The successfully created Custom Node |
Schema for a single Instance Custom Node
Instance Custom Node Schema
 - ▶{} 25 keys
Instance Custom Node Example
- ▶{} 11 keys
- "575ed18f7ae143cd83dc4aa6"
 - "My Instance Custom Node"
 - "Description of my instance custom node"
Schema for the body of a Instance Custom Node creation request
Instance Custom Node Post Schema
- ▶{} 6 keys
 - ▶{} 11 keys
 - 25
 - ▶[] 3 items
Instance Custom Node Post Example
- "My New Instance Custom Node"
 - "Description of my new instance custom node"
Schema for a collection of Custom Nodes within an instance
Instance Custom Nodes Schema
 - ▶{} 10 keys
Instance Custom Nodes Example
- ▶{} 8 keys
 - 1
 - 4
 - 1
 - 0
 - "name"
 - "asc"
