Instance Member Actions
https://api.losant.com/instances/INSTANCE_ID/members/USER_ID
Below are the various requests that can be performed against the Instance Member resource, as well as the expected parameters and the potential responses.
Delete
Deletes an instance member
DELETE https://api.losant.com/instances/INSTANCE_ID/members/USER_ID
all.Instance, all.User, instanceMember.*, or instanceMember.delete.
| INSTANCE_ID | ID associated with the instance | 575ec8687ae143cd83dc4a97 |
| USER_ID | ID associated with the instance member | 575ec8687ae143cd83dc4a94 |
| 200 | Success | If member was successfully deleted |
| 404 | Error | Error if instance or member was not found |
Returns an instance member
GET https://api.losant.com/instances/INSTANCE_ID/members/USER_ID
all.Instance, all.Instance.read, all.User, all.User.read, instanceMember.*, or instanceMember.get.
| 200 | Instance Member | A single instance member |
Patch
Modifies the role of an instance member
PATCH https://api.losant.com/instances/INSTANCE_ID/members/USER_ID
all.Instance, all.User, instanceMember.*, or instanceMember.patch.
The body of the request should be serialized JSON that validates against the Instance Member Patch schema. For example, the following would be a valid body for this request:
"role": "view"
-d '{"role":"view"}' \
| 200 | Instance Member Patch | The modified instance member |
Instance Member
Schema for an Instance member
Instance Member Schema
- ▶{} 9 keys
Instance Member Example
- "575ef90f7ae143cd83dc4aad"
- "view"
Schema for an Instance member modification request
Instance Member Patch Schema
Instance Member Patch Example
- "view"
Success
Success Schema
Success Example
