Instance Members Actions
https://api.losant.com/instances/INSTANCE_ID
/members
Below are the various requests that can be performed against the Instance Members resource, as well as the expected parameters and the potential responses.
Returns a collection of instance members
GET https://api.losant.com/instances/INSTANCE_ID
/members
A valid api access token is required to access this endpoint. The token must include at least one of the following scopes: all.Instance, all.Instance.read, all.User, all.User.read, instanceMembers.*, or instanceMembers.get.
INSTANCE_ID | ID associated with the instance | 575ec8687ae143cd83dc4a97 |
sortField | N | Field to sort the results by. Accepted values are: email, role | sortField=role | |
filterField | N | Field to filter the results by. Blank or not provided means no filtering. Accepted values are: email, role | filterField=email | |
filter | N | Filter to apply against the filtered field. Supports globbing. Blank or not provided means no filtering. | filter=my * instance |
https://api.losant.com/instances/INSTANCE_ID/members
Code | Type | Description |
200 | Instance Members | A collection of instance members |
404 | Error | Error if instance was not found |
Creates a new instance member
POST https://api.losant.com/instances/INSTANCE_ID
/members
A valid api access token is required to access this endpoint. The token must include at least one of the following scopes: all.Instance, all.User, instanceMembers.*, or instanceMembers.post.
The body of the request should be serialized JSON that validates against the Instance Member Post schema. For example, the following would be a valid body for this request:
"userId": "675ed18f7ae143cd83dc4bb7",
"role": "view"
-d '{"userId":"675ed18f7ae143cd83dc4bb7","role":"view"}' \
200 | Instance Member | The newly created instance member |
