Instance Notification Rule Actions
https://api.losant.com/instances/INSTANCE_ID/notification-rules/NOTIFICATION_RULE_ID
Below are the various requests that can be performed against the Instance Notification Rule resource, as well as the expected parameters and the potential responses.
Delete
Deletes a notification rule
DELETE https://api.losant.com/instances/INSTANCE_ID/notification-rules/NOTIFICATION_RULE_ID
all.Instance, all.User, instanceNotificationRule.*, or instanceNotificationRule.delete.
| INSTANCE_ID | ID associated with the instance | 575ec7417ae143cd83dc4a96 |
| NOTIFICATION_RULE_ID | ID associated with the notification rule | 575ec7417ae143cd83dc4a95 |
| 200 | Success | If notification rule was successfully deleted |
| 404 | Error | Error if notification rule was not found |
Evaluate
Queues the evaluation of a notification rule
POST https://api.losant.com/instances/INSTANCE_ID/notification-rules/NOTIFICATION_RULE_ID/evaluate
all.Instance, all.User, instanceNotificationRule.*, or instanceNotificationRule.evaluate.
The body of the request should be serialized JSON that validates against the Notification Rule Evaluation Options schema. For example, the following would be a valid body for this request:
"ignoreFrequencyCheck": true
-d '{"ignoreFrequencyCheck":true}' \
| 202 | Job Enqueued API Result | If the evaluation was successfully queued |
Retrieves information on a notification rule
GET https://api.losant.com/instances/INSTANCE_ID/notification-rules/NOTIFICATION_RULE_ID
all.Instance, all.Instance.read, all.User, all.User.read, instanceNotificationRule.*, or instanceNotificationRule.get.
| 200 | Notification Rule | Notification rule information |
Logs
Retrieves information on notification rule deliveries
GET https://api.losant.com/instances/INSTANCE_ID/notification-rules/NOTIFICATION_RULE_ID/logs
all.Instance, all.User, instanceNotificationRule.*, or instanceNotificationRule.logs.
| limit | N | Max log entries to return (ordered by time descending) | 1 | limit=10 |
| since | N | Look for log entries since this time (ms since epoch) | since=1465790400000 |
| 200 | Notification Rule Delivery Logs | Notification delivery information |
Patch
Updates information about a notification rule
PATCH https://api.losant.com/instances/INSTANCE_ID/notification-rules/NOTIFICATION_RULE_ID
all.Instance, all.User, instanceNotificationRule.*, or instanceNotificationRule.patch.
The body of the request should be serialized JSON that validates against the Notification Rule Patch schema. For example, the following would be a valid body for this request:
"name": "My Updated Notification Rule",
"enabled": false
-d '{"name":"My Updated Notification Rule","enabled":false}' \
| 200 | Notification Rule | Updated notification rule information |
Job Enqueued API Result Schema
Job Enqueued API Result Example
- "clnHvJbyVkOWAZwYAwLP4"
Notification Rule
Schema for a single notification rule
Notification Rule Schema
- ▶{} 18 keys
Notification Rule Example
- ▶{} 16 keys
- "585ec7417ae143cd83dc4a95"
- "60106426dc03c6aad06560ba"
- "instance"
- "575ed70c7ae143cd83dc4aa9"
- "user"
- "user"
- "organization"
- "My Notification Rule"
Schema for a set of Notification Rule delivery logs
Notification Rule Delivery Logs Schema
- "array"
Notification Rule Delivery Logs Example
- ▶{} 13 keys
Schema for evaluation options for a notification rule
Notification Rule Evaluation Options Schema
Notification Rule Evaluation Options Example
Schema for the body of a notification rule modification request
Notification Rule Patch Schema
- ▶{} 7 keys
Notification Rule Patch Example
- "My Updated Notification Rule"
Success
Success Schema
Success Example
