Instance Notification Rules Actions
https://api.losant.com/instances/INSTANCE_ID/notification-rules
Below are the various requests that can be performed against the Instance Notification Rules resource, as well as the expected parameters and the potential responses.
Returns the notification rules for an instance
GET https://api.losant.com/instances/INSTANCE_ID/notification-rules
all.Instance, all.Instance.read, all.User, all.User.read, instanceNotificationRules.*, or instanceNotificationRules.get.
| INSTANCE_ID | ID associated with the instance | 575ec7417ae143cd83dc4a96 |
| sortField | N | Field to sort the results by. Accepted values are: name, id, creationDate, lastUpdated | name | sortField=name |
| filterField | N | Field to filter the results by. Blank or not provided means no filtering. Accepted values are: name | filterField=key | |
| filter | N | Filter to apply against the filtered field. Supports globbing. Blank or not provided means no filtering. | filter=my*rule |
| 200 | Notification Rules | Collection of notification rules |
Create a new notification rule for an instance
POST https://api.losant.com/instances/INSTANCE_ID/notification-rules
all.Instance, all.User, instanceNotificationRules.*, or instanceNotificationRules.post.
The body of the request should be serialized JSON that validates against the Notification Rule Post schema. For example, the following would be a valid body for this request:
"name": "My New Notification Rule",
"targetType": "organization",
"targetQueryJson": "{}",
"emailConfig": {
"subjectTemplate": "Limit Exceeded",
"bodyTemplate": "Org has exceeded its payload limit",
"sendToTarget": "admins"
"ruleConfig": {
"ruleType": "payloadUsage",
"thresholdType": "percentOfLimit",
"threshold": 100
-d '{"name":"My New Notification Rule","targetType":"organization","targetQueryJson":"{}","emailConfig":{"subjectTemplate":"Limit Exceeded","bodyTemplate":"Org has exceeded its payload limit","sendToTarget":"admins"},"ruleConfig":{"ruleType":"payloadUsage","thresholdType":"percentOfLimit","threshold":100}}' \
| 201 | Notification Rule | The successfully created notification rule |
Notification Rule
Schema for a single notification rule
Notification Rule Schema
- ▶{} 18 keys
Notification Rule Example
- ▶{} 16 keys
- "585ec7417ae143cd83dc4a95"
- "60106426dc03c6aad06560ba"
- "instance"
- "575ed70c7ae143cd83dc4aa9"
- "user"
- "user"
- "organization"
- "My Notification Rule"
Schema for the body of a notification rule creation request
Notification Rule Post Schema
- ▶{} 8 keys
- ▶[] 4 items
Notification Rule Post Example
- "My New Notification Rule"
- "organization"
Notification Rules
Schema for a collection of notification rules
Notification Rules Schema
- ▶{} 11 keys
Notification Rules Example
- ▶{} 9 keys
- 1
- 4
- 1
- 0
- "name"
- "asc"
- "instance"
