Instance Organization Actions
https:// api.losant.com/instances/INSTANCE_ID
/orgs/ORG_ID
Instance Organization resource, as well as the expected
Deletes an organization
DELETE https:// api.losant.com/instances/INSTANCE_ID
/orgs/ORG_ID
all.Instance
, all.User
, instanceOrg.*
, or instanceOrg.delete
Path Component Description Example INSTANCE_ID ID associated with the instance 575ec8687ae143cd83dc4a97 ORG_ID ID associated with the organization 575ed6e87ae143cd83dc4aa8
Name Required Description Default Authorization Y The token for authenticating the request, prepended with Bearer
curl -H 'Content-Type: application/json' \ -H 'Accept: application/json' \ -H 'Authorization: Bearer YOUR_API_ACCESS_TOKEN' \ -X DELETE \ https://api.losant.com/instances/INSTANCE_ID/orgs/ORG_ID
Code Type Description 200 Success If organization was successfully deleted
Code Type Description 400 Error Error if malformed request 404 Error Error if instance or organization was not found
Returns device counts by day for the time range specified for this organization
GET https:// api.losant.com/instances/INSTANCE_ID
/orgs/ORG_ID
/deviceCounts
all.Instance
, all.Instance.read
, all.User
, all.User.read
, instanceOrg.*
, or instanceOrg.deviceCounts
Name Required Description Default Example start N Start of range for device count query (ms since epoch) start=0
end N End of range for device count query (ms since epoch) 0 end=1465790400000
curl -H 'Content-Type: application/json' \ -H 'Accept: application/json' \ -H 'Authorization: Bearer YOUR_API_ACCESS_TOKEN' \ -X GET \ https://api.losant.com/instances/INSTANCE_ID/orgs/ORG_ID/deviceCounts
Retrieves information on an organization
/orgs/ORG_ID
all.Instance
, all.Instance.read
, all.User
, all.User.read
, instanceOrg.*
, or instanceOrg.get
Name Required Description Default Example summaryInclude N Comma-separated list of summary fields to include in org summary summaryInclude=payloadCount
Returns notebook execution usage by day for the time range specified for this organization
/orgs/ORG_ID
/notebookMinuteCounts
all.Instance
, all.Instance.read
, all.User
, all.User.read
, instanceOrg.*
, or instanceOrg.notebookMinuteCounts
Name Required Description Default Example start N Start of range for notebook execution query (ms since epoch) start=0
end N End of range for notebook execution query (ms since epoch) end=1465790400000
curl -H 'Content-Type: application/json' \ -H 'Accept: application/json' \ -H 'Authorization: Bearer YOUR_API_ACCESS_TOKEN' \ -X GET \ https://api.losant.com/instances/INSTANCE_ID/orgs/ORG_ID/notebookMinuteCounts
Updates information about an organization
PATCH https:// api.losant.com/instances/INSTANCE_ID
/orgs/ORG_ID
all.Instance
, all.User
, instanceOrg.*
, or instanceOrg.patch
The body of the request should be serialized JSON that validates against
the Instance Owned Organization Patch schema. For example, the following would be a
valid body for this request:
{ "name" : "My Org" , "limits" : { "member" : 500 } , "auditLogEnabled" : true }
curl -H 'Content-Type: application/json' \ -H 'Accept: application/json' \ -H 'Authorization: Bearer YOUR_API_ACCESS_TOKEN' \ -X PATCH \ -d '{"name":"My Org","limits":{"member":500},"auditLogEnabled":true}' \ https://api.losant.com/instances/INSTANCE_ID/orgs/ORG_ID
Returns payload counts for the time range specified for all applications this organization owns
/orgs/ORG_ID
/payloadCounts
all.Instance
, all.Instance.read
, all.User
, all.User.read
, instanceOrg.*
, or instanceOrg.payloadCounts
Name Required Description Default Example start N Start of range for payload count query (ms since epoch) start=0
end N End of range for payload count query (ms since epoch) end=1465790400000
asBytes N If the resulting stats should be returned as bytes false asBytes=true
curl -H 'Content-Type: application/json' \ -H 'Accept: application/json' \ -H 'Authorization: Bearer YOUR_API_ACCESS_TOKEN' \ -X GET \ https://api.losant.com/instances/INSTANCE_ID/orgs/ORG_ID/payloadCounts
Code Type Description 200 Payload Stats Payload counts, by type and source
Returns payload counts per resolution in the time range specified for all application this organization owns
/orgs/ORG_ID
/payloadCountsBreakdown
all.Instance
, all.Instance.read
, all.User
, all.User.read
, instanceOrg.*
, or instanceOrg.payloadCountsBreakdown
resolution N Resolution in milliseconds. Accepted values are: 86400000, 3600000 86400000 resolution=86400000
includeNonBillable N If non-billable payloads should be included in the result false includeNonBillable=true
curl -H 'Content-Type: application/json' \ -H 'Accept: application/json' \ -H 'Authorization: Bearer YOUR_API_ACCESS_TOKEN' \ -X GET \ https://api.losant.com/instances/INSTANCE_ID/orgs/ORG_ID/payloadCountsBreakdown
Schema for the result of a device counts request
(root) {} 3 keys$schema: "http://json-schema.org/draft-07/schema#" type: "object" properties: {} 3 keysstart: {} 2 keysend: {} 2 keyscounts: {} 2 keys
(root) {} 3 keysstart: "1999-05-20T05:00:00.000Z" end: "1999-06-20T04:59:59.999Z" counts: [] 1 item
(root) {} 3 keys$schema: "http://json-schema.org/draft-07/schema#" type: "object" properties: {} 2 keystype: {} 1 keymessage: {} 1 key
(root) {} 2 keystype: "NotFound" message: "Application was not found"
Schema for the body of an Organization owned by an instance
(root) {} 5 keys$schema: "http://json-schema.org/draft-07/schema#" type: "object" properties: {} 25 keyscreationDate: {} 2 keyslastUpdated: {} 2 keysname: {} 3 keysid: {} 2 keysorgId: {} 2 keysinstanceId: {} 2 keysdescription: {} 2 keysiconColor: {} 2 keyslimits: {} 3 keyssummary: {} 2 keyswhitelistedEmailDomains: {} 2 keysauditLogEnabled: {} 1 keydisabledAt: {} 1 keyisReadOnly: {} 1 keytags: {} 3 keysreferralId: {} 2 keysmfaMode: {} 2 keysbanner: {} 3 keysplanId: {} 2 keyscustomerId: {} 2 keyssubscriptionId: {} 2 keysbillingEmail: {} 3 keyssubscriptionStatus: {} 2 keyscurrentPeriodStart: {} 2 keyscurrentPeriodEnd: {} 2 keysadditionalProperties: false required: [] 1 item
(root) {} 19 keyscreationDate: "2022-10-26T19:27:42.736Z" lastUpdated: "2024-10-24T17:04:32.009Z" name: "My Org" id: "60106426dc03c6aad06540bb" orgId: "60106426dc03c6aad06540bb" instanceId: "60106426dc03c6aad06560ba" description: "My Org Description" iconColor: "#057180" limits: {} 33 keyssummary: {} 27 keyswhitelistedEmailDomains: [] 0 itemsauditLogEnabled: false disabledAt: false isReadOnly: false tags: [] 1 itemmfaMode: "notRequired" banner: {} 2 keyscurrentPeriodStart: "2023-01-01T00:00:00.000Z" currentPeriodEnd: "2023-01-31T11:59:59.999Z"
Schema for the body of an Organization modification request within an instance
(root) {} 4 keys$schema: "http://json-schema.org/draft-07/schema#" type: "object" properties: {} 12 keysname: {} 3 keysdescription: {} 2 keysiconColor: {} 2 keyslimits: {} 3 keyswhitelistedEmailDomains: {} 2 keysauditLogEnabled: {} 1 keydisabledAt: {} 1 keyisReadOnly: {} 1 keytags: {} 3 keysreferralId: {} 2 keysmfaMode: {} 2 keysbanner: {} 3 keysadditionalProperties: false
(root) {} 3 keysname: "My Org" limits: {} 1 keyauditLogEnabled: true
Schema for the result of a notebook minute counts request
Schema for the result of a payload counts breakdown request
Schema for the result of a payload stats request
(root) {} 3 keys$schema: "http://json-schema.org/draft-07/schema#" type: "object" properties: {} 19 keysappFile: {} 2 keysdataTable: {} 2 keysdeviceCreate: {} 2 keysdeviceCommand: {} 2 keysdeviceConnect: {} 2 keysdeviceDisconnect: {} 2 keysdeviceState: {} 2 keysendpoint: {} 2 keysevent: {} 2 keysflowError: {} 2 keysinboundEmail: {} 2 keysintegration: {} 2 keysmqttIn: {} 2 keysmqttOut: {} 2 keysnotebook: {} 2 keysresourceJob: {} 2 keystimer: {} 2 keysvirtualButton: {} 2 keyswebhook: {} 2 keys
(root) {} 6 keystimer: {} 1 keydeviceState: {} 2 keysmqttOut: {} 1 keywebhook: {} 1 keydeviceConnect: {} 1 keydeviceDisconnect: {} 1 key
(root) {} 3 keys$schema: "http://json-schema.org/draft-07/schema#" type: "object" properties: {} 1 key
