Instance Organization Invite Actions
https://api.losant.com/instances/INSTANCE_ID/orgs/ORG_ID/invites/INVITE_ID
Below are the various requests that can be performed against the Instance Organization Invite resource, as well as the expected parameters and the potential responses.
Delete
Revokes an instance org invitation
DELETE https://api.losant.com/instances/INSTANCE_ID/orgs/ORG_ID/invites/INVITE_ID
all.Instance, all.User, instanceOrgInvite.*, or instanceOrgInvite.delete.
| INSTANCE_ID | ID associated with the instance | 575ec8687ae143cd83dc4a95 |
| ORG_ID | ID associated with the organization | 575ec8687ae143cd83dc4a97 |
| INVITE_ID | ID associated with the organization invite | 575ec8687ae143cd83dc4a94 |
| 200 | Success | If an invite was successfully deleted |
| 404 | Error | Error if instance, organization or invite was not found |
Returns an organization invite
GET https://api.losant.com/instances/INSTANCE_ID/orgs/ORG_ID/invites/INVITE_ID
all.Instance, all.Instance.read, all.User, all.User.read, instanceOrgInvite.*, or instanceOrgInvite.get.
| 200 | Organization Invitation | A single organization invite |
| 404 | Error | Error if instance, organization, or invite was not found |
Resend Invite
Resend an organization invite with modified role info
POST https://api.losant.com/instances/INSTANCE_ID/orgs/ORG_ID/invites/INVITE_ID
all.Instance, all.User, instanceOrgInvite.*, or instanceOrgInvite.resendInvite.
The body of the request should be serialized JSON that validates against the Organization Role Info schema. For example, the following would be a valid body for this request:
"role": "view"
-d '{"role":"view"}' \
| 201 | Organization Invitation | The new org invite |
Schema for a pending invitation to an Organization
Organization Invitation Schema
- ▶{} 9 keys
Organization Invitation Example
- ▶{} 9 keys
- "575ed71e7ae143cd83dc4aaa"
- "invitedUser@example.com"
- "edit"
- "2016-05-13T04:00:00.000Z"
- 4233600000
Schema for an Organization member's role info
Organization Role Info Schema
Organization Role Info Example
- "view"
Success
Success Schema
Success Example
