Instance Organization Members Actions
https://api.losant.com/instances/INSTANCE_ID/orgs/ORG_ID/members
Below are the various requests that can be performed against the Instance Organization Members resource, as well as the expected parameters and the potential responses.
Returns a collection of instance organization members
GET https://api.losant.com/instances/INSTANCE_ID/orgs/ORG_ID/members
all.Instance, all.Instance.read, all.User, all.User.read, instanceOrgMembers.*, or instanceOrgMembers.get.
| INSTANCE_ID | ID associated with the instance | 575ec8687ae143cd83dc4a97 |
| ORG_ID | ID associated with the organization | 575ec8687ae143cd83dc4a97 |
| sortField | N | Field to sort the results by. Accepted values are: email, role | sortField=role | |
| filterField | N | Field to filter the results by. Blank or not provided means no filtering. Accepted values are: email, role | filterField=email | |
| filter | N | Filter to apply against the filtered field. Supports globbing. Blank or not provided means no filtering. | filter=my * instance |
| 200 | Instance Organization Members | A collection of instance organization members |
| 404 | Error | Error if instance was not found |
Creates a new organization member
POST https://api.losant.com/instances/INSTANCE_ID/orgs/ORG_ID/members
all.Instance, all.User, instanceOrgMembers.*, or instanceOrgMembers.post.
The body of the request should be serialized JSON that validates against the Instance Org Member Post schema. For example, the following would be a valid body for this request:
"role": "view",
"applicationRoles": [
"resourceId": "575ef90f7ae143cd83dc4a4f",
"role": "none"
"userId": "675ed18f7ae143cd83dc4bb7"
-d '{"role":"view","applicationRoles":[{"resourceId":"575ef90f7ae143cd83dc4a4f","role":"none"}],"userId":"675ed18f7ae143cd83dc4bb7"}' \
| 200 | Instance Org Member | The newly created instance member |
Instance Org Member
Schema for an Instance Organization member
Instance Org Member Schema
- ▶{} 10 keys
Instance Org Member Example
- "575ef90f7ae143cd83dc4aad"
- "view"
Schema for an Instance Organization member creation request
Instance Org Member Post Schema
- ▶[] 2 items
Instance Org Member Post Example
- "view"
- "675ed18f7ae143cd83dc4bb7"
Schema for a collection of Organization members within an instance
Instance Organization Members Schema
- ▶{} 8 keys
Instance Organization Members Example
- 8
- "role"
- "asc"
