Instance Organizations Actions
https://api.losant.com/instances/INSTANCE_ID/orgs
Below are the various requests that can be performed against the Instance Organizations resource, as well as the expected parameters and the potential responses.
Get​
Returns the organizations associated with the current instance
Method And Url​
GET https://api.losant.com/instances/INSTANCE_ID/orgs
Authentication​
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.Instance, all.Instance.bounded, all.Instance.read, all.User, all.User.bounded, all.User.read, instanceOrgs.*, or instanceOrgs.get.
Request Path Components​
INSTANCE_IDID associated with the instance575ec8687ae143cd83dc4a97
Request Query Parameters​
sortFieldNField to sort the results by. Accepted values are: name, id, creationDate, lastUpdatednamesortField=name
filterFieldNField to filter the results by. Blank or not provided means no filtering. Accepted values are: namefilterField=name
filterNFilter to apply against the filtered field. Supports globbing. Blank or not provided means no filtering.filter=my*org
summaryIncludeNComma-separated list of summary fields to include in org summarysummaryInclude=payloadCount
queryNOrganization filter JSON object which overrides all other filter params. See Advanced Instance Organization Query for more details.query={"name":"Bob's Org","lastUpdated":"2022-01-30T17:18:11.911Z"}
Request Headers​
Curl Example​
Successful Responses​
CodeTypeDescription
200Instance OrganizationsA collection of organizations
Error Responses​
CodeTypeDescription
Post​
Create a new organization
Method And Url​
POST https://api.losant.com/instances/INSTANCE_ID/orgs
Authentication​
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.Instance, all.Instance.bounded, all.User, all.User.bounded, instanceOrgs.*, or instanceOrgs.post.
Request Headers​
Request Body​
The body of the request should be serialized JSON that validates against the Instance Owned Organization Post schema. For example, the following would be a valid body for this request:
"name": "My Org",
"limits": {
"member": 500
"auditLogEnabled": true
Curl Example​
CodeTypeDescription
201Instance OrganizationThe newly created organization
Error Responses​
CodeTypeDescription
Schemas​
Advanced Instance Organization Query​
Schema for advanced instance organization queries
Advanced Instance Organization Query Schema​
    {} 4 keys
    • "object"
      {} 14 keys
        {} 3 keys
          {} 3 keys
            {} 3 keys
              {} 1 key
                {} 1 key
                  {} 1 key
                    {} 1 key
                      {} 1 key
                        {} 1 key
                          {} 1 key
                            {} 1 key
                              {} 1 key
                                {} 1 key
                                  {} 1 key
                                • false
                              Advanced Instance Organization Query Example​
                                {} 2 keys
                                • "Bob's Org"
                                • "2022-01-30T17:18:11.911Z"
                              Error​
                              Error Schema​
                                {} 3 keys
                                • "object"
                                  {} 3 keys
                                    {} 1 key
                                      {} 1 key
                                        {} 2 keys
                                    Error Example​
                                      {} 2 keys
                                      • "NotFound"
                                      • "Application was not found"
                                    Instance Organization​
                                    Schema for an Organization owned by an instance
                                    Instance Organization Schema​
                                      {} 5 keys
                                      • "object"
                                        {} 25 keys
                                          {} 2 keys
                                            {} 2 keys
                                              {} 3 keys
                                                {} 2 keys
                                                  {} 2 keys
                                                    {} 2 keys
                                                      {} 2 keys
                                                        {} 2 keys
                                                          {} 3 keys
                                                            {} 2 keys
                                                              {} 2 keys
        {} 1 key
        {} 1 key
        {} 1 key
        {} 3 keys
        {} 2 keys
        {} 2 keys
        {} 3 keys
        {} 2 keys
        {} 2 keys
        {} 2 keys
        {} 3 keys
        {} 2 keys
        {} 2 keys
        {} 2 keys
        • false
        [] 1 item
        Instance Organization Example​
        {} 19 keys
        • "2022-10-26T19:27:42.736Z"
        • "2024-10-24T17:04:32.009Z"
        • "My Org"
        • "60106426dc03c6aad06540bb"
        • "60106426dc03c6aad06560ba"
        • "My Org Description"
        • "#057180"
        {} 34 keys
        {} 28 keys
        • [] 0 items
        • false
        • false
        • false
        [] 1 item
        • "notRequired"
        {} 2 keys
        • "2023-01-01T00:00:00.000Z"
        • "2023-01-31T11:59:59.999Z"
        Instance Owned Organization Post​
        Schema for the body of an Organization creation request within an instance
        Instance Owned Organization Post Schema​
        {} 5 keys
        • "object"
        {} 13 keys
        {} 3 keys
        {} 2 keys
        {} 2 keys
        {} 3 keys
        {} 3 keys
        {} 2 keys
        {} 1 key
        {} 1 key
        {} 1 key
        {} 3 keys
        {} 2 keys
        {} 2 keys
        {} 3 keys
        • false
        [] 1 item
        Instance Owned Organization Post Example​
        {} 3 keys
        • "My Org"
        {} 1 key
        • true
        Instance Organizations​
        Schema for a collection of Organizations within an instance
        Instance Organizations Schema​
        {} 3 keys
        • "object"
        {} 10 keys
        {} 2 keys
        {} 2 keys
        {} 1 key
        {} 1 key
        {} 1 key
        {} 1 key
        {} 1 key
        {} 1 key
        {} 1 key
        {} 2 keys
        Instance Organizations Example​
        {} 7 keys
        [] 1 item
        • 1
        • 2
        • 1
        • 0
        • "name"
        • "asc"
