https:// api.losant.com/instances/INSTANCE_ID /sandboxes/INSTANCE_SANDBOX_ID
Instance Sandbox resource, as well as the expected
Deletes a sandbox user account
DELETE https:// api.losant.com/instances/INSTANCE_ID /sandboxes/INSTANCE_SANDBOX_ID
all.Instance, all.User, instanceSandbox.*, or instanceSandbox.delete.
Path Component Description Example INSTANCE_ID ID associated with the instance 575ec8687ae143cd83dc4a97 INSTANCE_SANDBOX_ID ID associated with the sandbox user 575ec8687ae143cd83dc4a97
Name Required Description Default Authorization Y The token for authenticating the request, prepended with Bearer
curl -H 'Content-Type: application/json' \ -H 'Accept: application/json' \ -H 'Authorization: Bearer YOUR_API_ACCESS_TOKEN' \ -X DELETE \ https://api.losant.com/instances/INSTANCE_ID/sandboxes/INSTANCE_SANDBOX_ID
Code Type Description 200 Success If a sandbox was successfully deleted
Code Type Description 400 Error Error if malformed request 404 Error Error if sandbox or instance was not found
Returns device counts by day for the time range specified for all applications the sandbox user owns
GET https:// api.losant.com/instances/INSTANCE_ID /sandboxes/INSTANCE_SANDBOX_ID /deviceCounts
all.Instance, all.Instance.read, all.User, all.User.read, instanceSandbox.*, or instanceSandbox.deviceCounts.
Name Required Description Default Example start N Start of range for device count query (ms since epoch) start=0end N End of range for device count query (ms since epoch) end=1465790400000
curl -H 'Content-Type: application/json' \ -H 'Accept: application/json' \ -H 'Authorization: Bearer YOUR_API_ACCESS_TOKEN' \ -X GET \ https://api.losant.com/instances/INSTANCE_ID/sandboxes/INSTANCE_SANDBOX_ID/deviceCounts
Returns a sandbox user
all.Instance, all.Instance.read, all.User, all.User.read, instanceSandbox.*, or instanceSandbox.get.
Name Required Description Default Example summaryExclude N Comma-separated list of summary fields to exclude from user summary summaryExclude=payloadCountsummaryInclude N Comma-separated list of summary fields to include in user summary summaryInclude=payloadCount
Returns notebook execution usage by day for the time range specified for all applications the sandbox user owns
GET https:// api.losant.com/instances/INSTANCE_ID /sandboxes/INSTANCE_SANDBOX_ID /notebookMinuteCounts
all.Instance, all.Instance.read, all.User, all.User.read, instanceSandbox.*, or instanceSandbox.notebookMinuteCounts.
Name Required Description Default Example start N Start of range for notebook execution query (ms since epoch) start=0end N End of range for notebook execution query (ms since epoch) end=1465790400000
curl -H 'Content-Type: application/json' \ -H 'Accept: application/json' \ -H 'Authorization: Bearer YOUR_API_ACCESS_TOKEN' \ -X GET \ https://api.losant.com/instances/INSTANCE_ID/sandboxes/INSTANCE_SANDBOX_ID/notebookMinuteCounts
Returns payload counts for the time range specified for all applications the sandbox user owns
GET https:// api.losant.com/instances/INSTANCE_ID /sandboxes/INSTANCE_SANDBOX_ID /payloadCounts
all.Instance, all.Instance.read, all.User, all.User.read, instanceSandbox.*, or instanceSandbox.payloadCounts.
Name Required Description Default Example start N Start of range for payload count query (ms since epoch) start=0end N End of range for payload count query (ms since epoch) end=1465790400000asBytes N If the resulting stats should be returned as bytes false asBytes=true
curl -H 'Content-Type: application/json' \ -H 'Accept: application/json' \ -H 'Authorization: Bearer YOUR_API_ACCESS_TOKEN' \ -X GET \ https://api.losant.com/instances/INSTANCE_ID/sandboxes/INSTANCE_SANDBOX_ID/payloadCounts
Code Type Description 200 Payload Stats Payload counts, by type and source
Returns payload counts per resolution in the time range specified for all applications the sandbox user owns
GET https:// api.losant.com/instances/INSTANCE_ID /sandboxes/INSTANCE_SANDBOX_ID /payloadCountsBreakdown
all.Instance, all.Instance.read, all.User, all.User.read, instanceSandbox.*, or instanceSandbox.payloadCountsBreakdown.
Name Required Description Default Example start N Start of range for payload count query (ms since epoch) start=0end N End of range for payload count query (ms since epoch) end=1465790400000resolution N Resolution in milliseconds. Accepted values are: 86400000, 3600000 86400000 resolution=86400000asBytes N If the resulting stats should be returned as bytes false asBytes=trueincludeNonBillable N If non-billable payloads should be included in the result false includeNonBillable=true
curl -H 'Content-Type: application/json' \ -H 'Accept: application/json' \ -H 'Authorization: Bearer YOUR_API_ACCESS_TOKEN' \ -X GET \ https://api.losant.com/instances/INSTANCE_ID/sandboxes/INSTANCE_SANDBOX_ID/payloadCountsBreakdown
Restores a sandbox user account
PATCH https:// api.losant.com/instances/INSTANCE_ID /sandboxes/INSTANCE_SANDBOX_ID /undelete
all.Instance, all.User, instanceSandbox.*, or instanceSandbox.undelete.
curl -H 'Content-Type: application/json' \ -H 'Accept: application/json' \ -H 'Authorization: Bearer YOUR_API_ACCESS_TOKEN' \ -X PATCH \ https://api.losant.com/instances/INSTANCE_ID/sandboxes/INSTANCE_SANDBOX_ID/undelete
Schema for the result of a device counts request
(root) {} 3 keys$schema: "http://json-schema.org/draft-07/schema#" type: "object" properties: {} 3 keysstart: {} 2 keysend: {} 2 keyscounts: {} 2 keys
(root) {} 3 keysstart: "1999-05-20T05:00:00.000Z" end: "1999-06-20T04:59:59.999Z" counts: [] 1 item
(root) {} 3 keys$schema: "http://json-schema.org/draft-07/schema#" type: "object" properties: {} 2 keystype: {} 1 keymessage: {} 1 key
(root) {} 2 keystype: "NotFound" message: "Application was not found"
Schema for information about a sandbox user within an instance domain
(root) {} 3 keys$schema: "http://json-schema.org/draft-07/schema#" type: "object" properties: {} 32 keysid: {} 2 keysinstanceSandboxId: {} 2 keysinstanceId: {} 2 keyscreationDate: {} 2 keyspermanentDeletion: {} 2 keysdataDeletion: {} 2 keyslastUpdated: {} 2 keyslastSuccessfulLogin: {} 2 keyslastFailedLogin: {} 2 keysfailedLoginCount: {} 1 keypasswordLastUpdated: {} 2 keysemail: {} 3 keysfirstName: {} 3 keyslastName: {} 2 keyscompanyName: {} 2 keystitle: {} 2 keysphoneNumber: {} 2 keyslocation: {} 2 keysurl: {} 2 keystokenCutoff: {} 2 keysemailVerified: {} 1 keyneedsToVerifyEmail: {} 1 keytwoFactorAuthEnabled: {} 1 keyfullName: {} 1 keygithubName: {} 1 keyavatarUrl: {} 3 keyslimits: {} 3 keyssummary: {} 2 keyscurrentPeriodStart: {} 2 keyscurrentPeriodEnd: {} 2 keysssoLinked: {} 1 keyorgs: {} 2 keys
(root) {} 18 keysid: "575ed70c7ae143cd83dc4aa9" instanceId: "575ed70c7ae143cd83dc4aa9" instanceSandboxId: "575ed70c7ae143cd83dc4aa9" creationDate: "2016-06-13T04:00:00.000Z" lastUpdated: "2016-06-13T04:00:00.000Z" passwordLastUpdated: "2016-06-13T04:00:00.000Z" email: "email@example.com" firstName: "Example" lastName: "Name" companyName: "Example, Inc." url: "https://example.com" emailVerified: true needsToVerifyEmail: false twoFactorAuthEnabled: false fullName: "Example Name" summary: {} 8 keysorgs: [] 1 itemssoLinked: false
Schema for the result of a notebook minute counts request
Schema for the result of a payload counts breakdown request
Schema for the result of a payload stats request
(root) {} 3 keys$schema: "http://json-schema.org/draft-07/schema#" type: "object" properties: {} 19 keysappFile: {} 2 keysdataTable: {} 2 keysdeviceCreate: {} 2 keysdeviceCommand: {} 2 keysdeviceConnect: {} 2 keysdeviceDisconnect: {} 2 keysdeviceState: {} 2 keysendpoint: {} 2 keysevent: {} 2 keysflowError: {} 2 keysinboundEmail: {} 2 keysintegration: {} 2 keysmqttIn: {} 2 keysmqttOut: {} 2 keysnotebook: {} 2 keysresourceJob: {} 2 keystimer: {} 2 keysvirtualButton: {} 2 keyswebhook: {} 2 keys
(root) {} 6 keystimer: {} 1 keydeviceState: {} 2 keysmqttOut: {} 1 keywebhook: {} 1 keydeviceConnect: {} 1 keydeviceDisconnect: {} 1 key
(root) {} 3 keys$schema: "http://json-schema.org/draft-07/schema#" type: "object" properties: {} 1 key
