Instance Sandboxes Actions
https://api.losant.com/instances/INSTANCE_ID/sandboxes
Below are the various requests that can be performed against the Instance Sandboxes resource, as well as the expected parameters and the potential responses.
Get​
Returns a collection of instance sandboxes
Method And Url​
GET https://api.losant.com/instances/INSTANCE_ID/sandboxes
Authentication​
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.Instance, all.Instance.bounded, all.Instance.read, all.User, all.User.bounded, all.User.read, instanceSandboxes.*, or instanceSandboxes.get.
Request Path Components​
INSTANCE_IDID associated with the instance575ec8687ae143cd83dc4a97
Request Query Parameters​
summaryExcludeNComma-separated list of summary fields to exclude from user summarysummaryExclude=payloadCount
summaryIncludeNComma-separated list of summary fields to include in user summarysummaryInclude=payloadCount
sortFieldNField to sort the results by. Accepted values are: firstName, lastName, email, id, creationDate, lastSuccessfulLogin, lastFailedLogin, failedLoginCount, lastUpdatedemailsortField=firstName
startingAfterIdNExclusive ID from which to begin queryingstartingAfterId=575ec8687ae143cd83dc4a97
endingBeforeIdNExclusive ID at which to end queryingendingBeforeId=575ec8687ae143cd83dc4a97
limitNHow many items to return100limit=10
filterFieldNField to filter the results by. Blank or not provided means no filtering. Accepted values are: firstName, lastName, emailfilterField=firstName
filterNFilter to apply against the filtered field. Supports globbing. Blank or not provided means no filtering.filter=my * instance
includeDeletedNIf the result of the request should also include deleted sandboxes.includeDeleted=true
Request Headers​
Curl Example​
Successful Responses​
CodeTypeDescription
200Instance SandboxesCollection of instance sandboxes
Error Responses​
CodeTypeDescription
Schemas​
Error​
Error Schema​
    {} 3 keys
    • "object"
      {} 3 keys
        {} 1 key
          {} 1 key
            {} 2 keys
        Error Example​
          {} 2 keys
          • "NotFound"
          • "Application was not found"
        Instance Sandboxes​
        Schema for a collection of instance associated sandboxes
        Instance Sandboxes Schema​
          {} 3 keys
          • "object"
            {} 11 keys
              {} 2 keys
                {} 2 keys
                  {} 1 key
                    {} 1 key
                      {} 2 keys
                        {} 2 keys
                          {} 1 key
                            {} 1 key
                              {} 1 key
                                {} 2 keys
                                  {} 1 key
                              Instance Sandboxes Example​
                                {} 7 keys
                                • 2
                                  [] 2 items
                                  • 100
                                  • "575ed70c7ae143cd83dc4aa9"
                                  • "firstName"
                                  • "asc"
                                  • false
