Private File Actions
https://api.losant.com/applications/APPLICATION_ID/privateFiles/PRIVATE_FILE_ID
Below are the various requests that can be performed against the Private File resource, as well as the expected parameters and the potential responses.
Delete
Deletes a private file or directory, if a directory all the contents that directory will also be removed.
DELETE https://api.losant.com/applications/APPLICATION_ID/privateFiles/PRIVATE_FILE_ID
all.Application, all.Application.cli, all.Organization, all.User, all.User.cli, privateFile.*, or privateFile.delete.
| PRIVATE_FILE_ID | ID associated with the private file | 575ec76c7ae143cd83dc4a96 |
| 200 | Success | If private file was successfully deleted |
| 404 | Error | Error if private file was not found |
Retrieves information on a private file
GET https://api.losant.com/applications/APPLICATION_ID/privateFiles/PRIVATE_FILE_ID
all.Application, all.Application.cli, all.Application.read, all.Organization, all.Organization.read, all.User, all.User.cli, all.User.read, privateFile.*, or privateFile.get.
| urlTTL | N | Time in seconds that the private file url will be valid for. Only applies to private files of type 'file'. If 0, no url will be returned. | 900 | urlTTL=900 |
| 200 | File Schema | Private file information |
Move
Move a private file or the entire contents of a directory
POST https://api.losant.com/applications/APPLICATION_ID/privateFiles/PRIVATE_FILE_ID/move
all.Application, all.Application.cli, all.Organization, all.User, all.User.cli, privateFile.*, or privateFile.move.
| name | N | The new name of the private file or directory | name=fileA | |
| parentDirectory | N | The new parent directory for the private file or directory to move into. | parentDirectory=/new/location/here | |
| 201 | File Schema | Returns a new private file or directory that was created by the move, if a directory a job will kick off to move all the directories children. |
Patch
Reupload a private file
PATCH https://api.losant.com/applications/APPLICATION_ID/privateFiles/PRIVATE_FILE_ID
all.Application, all.Application.cli, all.Organization, all.User, all.User.cli, privateFile.*, or privateFile.patch.
The body of the request should be serialized JSON that validates against the File Patch schema. For example, the following would be a valid body for this request:
"fileSize": 500,
"contentType": "image",
"fileDimensions": {
"width": 200,
"height": 200
-d '{"fileSize":500,"contentType":"image","fileDimensions":{"width":200,"height":200}}' \
| 201 | File Upload Post Response | Successfully updated private file and the information needed to upload the file content |
Upload
Uploads the private file
POST https://api.losant.com/applications/APPLICATION_ID/privateFiles/PRIVATE_FILE_ID/upload
all.Application, all.Application.cli, all.Organization, all.User, all.User.cli, privateFile.*, or privateFile.upload.
The body of the request should be a multipart form data post containing the following:
| privateFile | Y | The content of the private file to upload | `` |
curl -H 'Content-Type: multipart/form-data' \
-F privateFile=@localfilename' \
| 200 | File Schema | Updated private file content |
| 404 | Error | Error if file was not found |
File Schema
Schema for a single public or private file
File Schema Schema
- ▶{} 16 keys
File Schema Example
- ▶{} 12 keys
- "575ed70c7ae143cd83dc4aa9"
- "user"
- "pending"
- "file.csv"
- "file"
- 500
- "text/csv"
File Patch
Schema to patch a public or private file
File Patch Schema
File Patch Example
- 500
- "image"
Schema with the information needed to upload public or private file contents
File Upload Post Response Schema
- ▶[] 2 items
File Upload Post Response Example
- ▶{} 13 keys
- "user"
- "pending"
- "file.csv"
- "file"
- 500
- "text/csv"
Success
Success Schema
Success Example
