Private Files Actions
https://api.losant.com/applications/APPLICATION_ID/privateFiles
Below are the various requests that can be performed against the Private Files resource, as well as the expected parameters and the potential responses.
Returns the private files for an application
GET https://api.losant.com/applications/APPLICATION_ID/privateFiles
all.Application, all.Application.cli, all.Application.read, all.Organization, all.Organization.read, all.User, all.User.cli, all.User.read, privateFiles.*, or privateFiles.get.
| sortField | N | Field to sort the results by. Accepted values are: lastUpdated, type, name, creationDate | lastUpdated | sortField=name |
| filterField | N | Field to filter the results by. Blank or not provided means no filtering. Accepted values are: name | filterField=name | |
| filter | N | Filter to apply against the filtered field. Supports globbing. Blank or not provided means no filtering. | filter=myFile | |
| type | N | Limit by the type (file or directory) of the file | type=file | |
| status | N | Limit the result to only files of this status. Accepted values are: completed, pending | status=completed | |
| directory | N | Get private files that are inside of this directory | directory=/a/path/ | |
| urlTTL | N | Time in seconds that the private file url will be valid for. Only applies to private files of type 'file'. If 0, no url will be returned. | 900 | urlTTL=900 |
| 200 | Files Schema | Collection of private files |
Create a new private file for an application
POST https://api.losant.com/applications/APPLICATION_ID/privateFiles
all.Application, all.Application.cli, all.Organization, all.User, all.User.cli, privateFiles.*, or privateFiles.post.
The body of the request should be serialized JSON that validates against the File Post schema. For example, the following would be a valid body for this request:
"name": "file.csv",
"type": "file",
"parentDirectory": "/",
"fileSize": 500,
"contentType": "text/csv"
-d '{"name":"file.csv","type":"file","parentDirectory":"/","fileSize":500,"contentType":"text/csv"}' \
| 201 | File Upload Post Response | Successfully created private file and the information needed to upload the file content |
File Post
Schema to create a single public or private file or directory
File Post Schema
- ▶{} 6 keys
- ▶[] 2 items
File Post Example
- "file.csv"
- "file"
- 500
- "text/csv"
Schema with the information needed to upload public or private file contents
File Upload Post Response Schema
- ▶[] 2 items
File Upload Post Response Example
- ▶{} 13 keys
- "575ed70c7ae143cd83dc4aa9"
- "user"
- "pending"
- "file.csv"
- "file"
- 500
- "text/csv"
Files Schema
Schema for a collection of public or private files
Files Schema Schema
- ▶{} 10 keys
Files Schema Example
- ▶[] 2 items
- 2
Usage of Response
After making a Private Files: Post request to Losant with the information about your file, you will need to make a second request using the information from that response object (the upload property) to actually place the file onto the cloud storage service.
In the upload field of the Private Files: Post response, to perform the actual upload of your file. For example, below is how to use curl and the values from the response to perform the upload of the file data:
curl -X POST \
-F 'Content-Type=<RESPONSE_OBJECT.upload.fields.Content-Type>' \
-F 'key=<RESPONSE_OBJECT.upload.fields.key>' \
-F 'X-Amz-Algorithm=<RESPONSE_OBJECT.upload.fields.X-Amz-Algorithm>' \
-F 'X-Amz-Credential=<RESPONSE_OBJECT.upload.fields.X-Amz-Credential>' \
-F 'X-Amz-Date=<RESPONSE_OBJECT.upload.fields.X-Amz-Date>' \
-F 'Policy=<RESPONSE_OBJECT.upload.fields.Policy>' \
-F 'X-Amz-Signature=<RESPONSE_OBJECT.upload.fields.X-Amz-Signature>' \
-F 'file=@<YOUR_LOCAL_FILE_PATH>' \
'<RESPONSE_OBJECT.upload.url>'
As another example, here is how you would upload the file contents using JavaScript in a browser:
var filePostResponse = /* result of Losant API Files POST call */;
var fileBlob = /* a blob, buffer, or browser file instance */;
var formData = new FormData();
formData.append('Content-Type',
filePostResponse.upload.fields['Content-Type']);
formData.append('key', filePostResponse.upload.fields.key);
formData.append('X-Amz-Algorithm',
filePostResponse.upload.fields['X-Amz-Algorithm']);
formData.append('X-Amz-Credential',
filePostResponse.upload.fields['X-Amz-Credential']);
formData.append('X-Amz-Date',
filePostResponse.upload.fields['X-Amz-Date']);
formData.append('Policy', filePostResponse.upload.fields['Policy']);
formData.append('X-Amz-Signature',
filePostResponse.upload.fields['X-Amz-Signature']);
formData.append('file', fileBlob);
var xhr = new XMLHttpRequest();
xhr.open('POST', filePostResponse.upload.url, true);
xhr.send(formData);
