Resource Jobs Actions
https://api.losant.com/applications/APPLICATION_ID/resource-jobs
Below are the various requests that can be performed against the Resource Jobs resource, as well as the expected parameters and the potential responses.
Returns the resource jobs for an application
GET https://api.losant.com/applications/APPLICATION_ID/resource-jobs
all.Application, all.Application.read, all.Organization, all.Organization.read, all.User, all.User.read, resourceJobs.*, or resourceJobs.get.
| sortField | N | Field to sort the results by. Accepted values are: name, id, creationDate, lastUpdated, lastExecutionRequested, resourceType | name | sortField=name |
| filterField | N | Field to filter the results by. Blank or not provided means no filtering. Accepted values are: name, resourceType | filterField=device | |
| filter | N | Filter to apply against the filtered field. Supports globbing. Blank or not provided means no filtering. | filter=my*job |
| 200 | Resource Jobs | Collection of resource jobs |
Create a new resource job for an application
POST https://api.losant.com/applications/APPLICATION_ID/resource-jobs
all.Application, all.Organization, all.User, resourceJobs.*, or resourceJobs.post.
The body of the request should be serialized JSON that validates against the Resource Job Post schema. For example, the following would be a valid body for this request:
"name": "Example Resource Job",
"resourceType": "device",
"queryJson": "{ \"name\": \"my device\"}"
-d '{"name":"Example Resource Job","resourceType":"device","queryJson":"{ \"name\": \"my device\"}"}' \
| 201 | Resource Job | Successfully created resource job |
Resource Job
Schema for a single resource job
Resource Job Schema
- ▶{} 19 keys
Resource Job Example
- ▶{} 11 keys
- "Example Resource Job"
- 60
- 60000
- "6328c6c026517badf9142116"
- 1
- "2022-09-19T19:45:04.453Z"
- "6328c6c026517badf914211a"
- "device"
- "{ "name": "my device"}"
Resource Job Post
Schema for a resource job creation
Resource Job Post Schema
- ▶{} 13 keys
- ▶[] 2 items
Resource Job Post Example
- "device"
Resource Jobs
Schema for a collection of Resource Jobs
Resource Jobs Schema
- ▶{} 10 keys
Resource Jobs Example
- ▶{} 6 keys
- 1
- 4
- "name"
- "asc"
