SAML: Login URL Node
The SAML: Login URL Node allows a workflow to create a login URL for a Security Assertion Markup Language 2.0 (SAML) single sign-on (SSO) identity provider.
The configuration for the The SAML: Login URL Node requires two SAML 2.0 metadata XMLs.
Service Provider Metadata Template
An XML EntityDescriptor describing the service provider - this field supports templating. Here is an example:
<EntityDescriptor
xmlns:md="urn:oasis:names:tc:SAML:2.0:metadata"
xmlns:saml="urn:oasis:names:tc:SAML:2.0:assertion"
xmlns:ds="http://www.w3.org/2000/09/xmldsig#"
entityID="saml-poc">
<SPSSODescriptor
protocolSupportEnumeration="urn:oasis:names:tc:SAML:2.0:protocol">
<!-- insert ds:Signature element (omitted) -->
<NameIDFormat>urn:oasis:names:tc:SAML:1.1:nameid-format:emailAddress</NameIDFormat>
<AssertionConsumerService
isDefault="true"
index="0"
Binding="urn:oasis:names:tc:SAML:2.0:bindings:HTTP-POST"
Location="http://example.com/saml/assert"/>
</SPSSODescriptor>
</EntityDescriptor>
Identity Provider Metadata Template
An XML EntityDescriptor describing the identity provider - this field supports templating. Here is an example:
<EntityDescriptor
entityID="https://example.com/saml2/idp/metadata.php">
<IDPSSODescriptor
<SingleLogoutService
Binding="urn:oasis:names:tc:SAML:2.0:bindings:HTTP-Redirect"
Location="http://example.com/saml2/idp/SingleLogoutService.php"/>
<NameIDFormat>urn:oasis:names:tc:SAML:2.0:nameid-format:transient</NameIDFormat>
<SingleSignOnService
Location="https://example.com/saml2/idp/login.php"/>
</IDPSSODescriptor>
</EntityDescriptor>
It is required you specify where on the payload path you want the created SAML login URL to be placed. If the creation is successful it will store the URL in an object with a redirectUrl property at this path. If the URL creation errors, the result will be an object with an error property.
Here’s an example output from running the above workflow ...
"saml": {
"redirectUrl": "https://example.com/saml2/idp/login.php/Nnr5wYbUCAZ86sGrTA7sKJBzKfsjb9LX?..."
"saml": {
"message": "Multiple metadata entitydescriptor"
