JWT: Decode Node
The JWT: Decode Node allows a workflow to decode a JSON Web Token on the payload.
The JWT: Decode Node requires a token template and a result path. There is one optional configuration which is a checkbox called Complete Payload, Headers and Signature
. If this is checked and the JWT successfully decoded, the result will include the JWT’s signature, decoded payload and headers.
Example Result Complete Payload, Headers and Signature turned off:
"jwtPayload": {
"iss":"issuer.com"
"scope":"https://www.googleapis.com/auth/cloud-platform"
"aud":"https://www.googleapis.com/oauth2/v4/token"
"iat":1509374356
"exp":1509460756
Example Result Complete Payload, Headers and Signature turned on:
"jwtPayload": {
"header": {
"alg": "RS256",
"typ": "JWT"
"payload": {
"iss":"issuer.com"
"iat":1509374356
"exp":1509460756
"signature": "aSinGatuR_e"
Outputs
The JWT: Decode Node has one output field. The Destination Path
field takes a payload path. If successfully decoded, the JWT decode result will be placed on the payload at this path, otherwise it will be an error object.
