Gateway Edge Agent Changelog
This file represents all changes to the Losant Gateway Edge Agent since its initial release. This project adheres to Semantic Versioning.
2.0.0 - 2025-12-09
Breaking Changes
Added
- AWS S3: Get Node allows the requested file to be written directly to a given local disk path.
- AWS S3: Put Node allows the source of the content of the file to be read from a local disk path.
- CSV: Decode Node includes optional field to strip starting BOM from the source string.
Changed
- Upgraded various library dependencies.
- Upgraded Node.js version to 24.11.1.
1.58.0 - 2025-10-28
Added
- Array Node now supports the "Deduplicate By" operation and the "Filter" operation.
- SQL Node now supports the connection field
instanceNameTemplatefor MSSQL databases.
Changed
- HTTP Node allows a body to be sent on a
DELETErequest. - Upgraded various library dependencies.
- Upgraded Node.js version to 22.22.0.
1.57.0 - 2025-09-23
Changed
- Upgraded Node.js version to 22.19.0.
- Upgraded Alpine to 3.22.
Fixed
- Removed unexpected extra OPC UA logging.
1.56.0 - 2025-08-19
Changed
- Upgraded Node.js version to 22.18.0.
Fixed
- Fixed issue with the
lookupHandlebars helper when it is not given the expected number of arguments.
1.55.0 - 2025-07-15
Changed
- Upgraded Node.js version to 22.17.0.
1.54.0 - 2025-06-05
Added
- Allen-Bradley: Read and Allen-Bradley: Write Nodes now support a timeout template field, which defines the amount of time to wait before timing out the request.
- Allen-Bradley: Read Node now supports a length template field to specify the length of the array. When this field is not given, it will read the first item in the array.
Changed
- Upgraded Node.js version to 22.16.0.
- Allen-Bradley: Read and Allen-Bradley: Write Nodes ignores data type field, and it has been completely removed from the UI. Data type is based on the data type from the PLC given tag.
1.53.0 - 2025-04-24
Changed
- Allen-Bradley: Write Node casts the value fields based on the data type from the PLC of the given tag.
- Allen-Bradley: Read and Allen-Bradley: Write Nodes instructions are run as a batch call to the PLC.
- Allen-Bradley: Read, Allen-Bradley: Write, Beckhoff: Read, Beckhoff: Write, Modbus: Read, and Modbus: Write Nodes verify the host when the client is attempting to make a connection instead of every time a node is run.
- Allen-Bradley: Read and Allen-Bradley: Write Nodes cache the tag metadata information per client in order to properly validate, cast, and write tag values.
- Allen-Bradley: Read and Allen-Bradley: Write Nodes time out when the instructions take longer than the
MAX_EXTERNAL_CALL_TIMEto process.
Fixed
- Beckhoff Trigger localAdsPort field defaults to
32750. - Allen-Bradley: Read Node does not allow a Result Key to be
plcPropertiesor start withplcProperties.. - Allen-Bradley: Read and Allen-Bradley: Write Nodes automatically reconnect when the client connection errors or disconnects while the client is waiting for the next instruction.
- Allen-Bradley: Read Node returns PLC errors when trying to access a bit index outside of the range.
- Allen-Bradley: Read Node returns an empty string when the string tag is defined on the PLC but its value is undefined.
1.52.0 - 2025-03-18
Added
- ✨ New Snowflake Node.
Changed
- Upgraded Node.js version to 22.14.0.
1.51.0 - 2025-02-11
Added
- Beckhoff Write Node now supports autoFill field.
Changed
- Upgraded Node.js version to 22.13.1.
- Allen-Bradley: Read Node will only set one error for each key.
- Upgraded Alpine to 3.21.
- Allen-Bradley: Read and Allen-Bradley: Write Nodes keep a queue of instructions to run per client connection and have a maximum number of instructions in the queue.
- Beckhoff: Read Node has improved read performance.
Fixed
- Allen-Bradley: Read and Allen-Bradley: Write Nodes will add errors to the payload path during any step when processing an instruction.
- Modbus: Read and Modbus: Write Nodes will properly refresh an existing client or create a new client if the existing one was already closed.
- Payload Format helpers are consistent in returning either a string or object depending on the function.
1.50.1 - 2024-12-17
Added
- Expressions have support for the new function includes.
- HTTP Node can now be configured to not automatically follow redirects.
Changed
- Upgraded Node.js version to 20.18.1.
1.50.0 - 2024-11-05
Added
- Beckhoff Trigger configuration fields can now be pulled by name from the Edge Agent configuration file.
Changed
- Upgraded Node.js version to 20.18.0.
Fixed
- Beckhoff Trigger now correctly cleans up subscriptions on GEA or Beckhoff client shutdown.
1.49.0 - 2024-10-01
Added
- ✨ New Beckhoff Trigger.
- ✨ New Beckhoff Read Node.
- ✨ New Beckhoff Write Node.
- New Docker Healthcheck option, including new environment variables:
HEALTH_CHECK_ENABLED,HEALTH_CHECK_PORTandHEALTH_CHECK_OFFLINE_IS_UNHEALTHY.
Changed
- Upgraded Node.js version to 20.17.0.
1.48.1 - 2024-08-27
Changed
- Upgraded Node.js version to 20.16.0
1.48.0 - 2024-07-23
Added
- ✨ New Throw Error Node.
- ✨ New Mailgun Node.
Changed
- Upgraded Node.js version to 20.15.1.
{{format}}Handlebars helper acceptslocaleas optional parameter when the given input is a number.- Lambda Node will retry invoking a function when certain DNS errors are returned.
1.47.0 - 2024-06-18
Changed
- Upgraded Node.js version to 20.14.0.
{{formatDate}}and{{currentDateTime}}Handlebars helpers now accepttzandlocaleas optional parameters.{{formatDateRelative}}Handlebars helper now acceptslocaleas an optional parameter.- HTTP Node now supports body types "From URL" and "JSON Template".
- HTTP Node now supports templates for the Request Method.
HEADas a Request Method. - HTTP Node now includes
requestDurationproperty in the response object. - AWS: Lambda Node now supports Timeout Template field.
- SQL Node improved performance when returning large data sets from a MySQL database.
1.46.0 - 2024-05-14
Added
- ✨ New Instance Edge Custom Nodes.
- ✨ New
{{substring}}Helper, which returns a part of a string given a starting index and an optional ending index.
Changed
- Upgraded Node.js version to 20.12.2.
- Modbus: Read and Modbus: Write Nodes include new connection type option
Serial ASCII Connection. - Delay Node will no longer wait if this is the last node in a workflow.
- SendGrid Node includes the unique arguments application ID, workflow ID, and workflow version on email sends. These custom arguments can be found in the email details information in the SendGrid UI.
{{formatDate}}Helper will cast stringified numbers to then format as dates.- SQL Node allows environment variable
MAX_SQL_NODE_CLIENT_POOL_SIZEto set the maximum pool size for database types MSSQL, MySQL and PostgreSQL. The default value is 7. - Losant API Node will error when a required URL parameter is missing.
Removed
- Twilio Node optional field
Max SMS Priceis removed in this version. This field is deprecated by Twilio and this field will be ignored by Twilio after June 3rd, 2024 for all edge agent versions.
1.45.0 - 2024-04-09
Added
- ✨ New Output / WhatsApp Node.
Changed
- Upgraded Node.js version to 20.12.1.
- Upgraded Alpine Docker image to version 3.19.
- Custom Node payloads now include the application ID.
1.44.0 - 2024-03-05
Added
- Edge Agent containers now store up to 256 log messages per logging level in memory, which can be retrieved remotely and streamed through the Losant user interface when the device is connected to the MQTT broker.
- MQTT External Broker Client Configuration includes new option of
protocolVersionto allow connections to either MQTT 5 brokers or MQTT 3.1.1 brokers.
Changed
- Upgraded Node.js version to 20.11.1.
- OPC UA Triggers configured with a named trigger configuration now include a
dataTypeproperty on the payload. - OPC UA Browse Node, OPC UA Call Node, OPC UA Read Node, and OPC UA Write Node security policy
Basic-128 RSA-15is deprecated by OPC UA and has been removed as a valid option.
Fixed
- OPC UA Read Node with an integer identifier correctly defaults a result key.
1.43.3 - 2024-01-30
Added
- The SendGrid Node supports attachments.
Changed
- The Redis Node is smarter about keeping cached connections.
sourceTimestampproperty on the initial payload if applicable.
Fixed
- The OPC UA Trigger logs an error message if the specified Agent Trigger Name is not found.
- The MQTT Trigger deploys to the edge agent when topic contains a leading slash.
1.43.2 - 2023-12-14
Changed
- Upgraded Node.js to version 18.19.0.
- Added the Alpine/Debian installed CA certificates as trusted certificates in addition to the built-in Node.js trusted certificates.
- The Function Node is now allowed to use
async/awaitand allowed to return aPromise. - The Function Node now has access to the container's environment variables.
- The Function Node can now
requireglobally installed node modules.
1.43.1 - 2023-11-07
Changed
- Upgraded Node.js to version 18.18.2.
- Better validation on subscription topics from TOML file MQTT External Broker Trigger Configuration.
- MQTT client logs a warning message when an external broker topic subscription fails and an info message when a topic subscription succeeds.
1.43.0 - 2023-10-05
Added
- ✨ New Logic / CBOR Encode Node.
- ✨ New Logic / CBOR Decode Node.
- New environment variables for the Function Node, including
RAW_FUNCTION_STARTUP_TIMEOUT,RAW_FUNCTION_MEM_LIMIT_MBandRAW_FUNCTION_INSTANCES.
Changed
- Upgraded Node.js to version 18.18.0.
BROKER_PROTOCOLenvironment variable no longer has to include "://";mqtts,mqtt,ws, andwssare all valid values.- Broker SSL Keys, Web Server SSL Key, and Local Broker SSL Key now accept ECDSA keys.
Fixed
- All Allen-Bradley node connection errors are now properly returned to the user.
- Redis Node properly closes the client when rapidly trying to connect with invalid credentials.
1.42.0 - 2023-08-29
Added
- ✨ New Data / Azure Table Storage Node.
- The GEA can now connect as a client to third-party MQTT brokers, allowing for publishing messages and subscribing to topics through the MQTT Output Node and MQTT Trigger respectively.
Changed
- Upgraded Node.js to version 18.17.1.
- Function Node transforms Sets to Arrays and Maps to Objects when included on the payload.
- GCP Storage: Get, GCP Storage: Put, GCP: BigQuery, GCP: Function, GCP: ML, and GCP Pub/Sub Nodes have a "Project ID Template" field that, when set, will override the project ID on the Account Key JSON.
Fixed
- MQTT Trigger now correctly differentiates between publishes from the Losant MQTT Broker and publishes from its local MQTT broker when using the same topic.
- Fixed issue with segmentation fault on startup with the Debian ARM7 image on 32-bit ARM hardware.
- Tweet Node is deprecated and cannot be added to any existing or new workflow.
- SQL Node contains a fix for a race condition that occurred when two nodes tried to access a SQL server with invalid configuration.
1.41.1 - 2023-07-31
Fixed
- Fixed issue with segmentation fault on startup with the Alpine ARM7 image on 32 bit ARM hardware.
1.41.0 - 2023-07-25
Added
- Edge Custom Nodes can be used in edge workflows.
- The
developversion of an Edge Custom Node can be directly deployed and run on the edge agent.
Changed
- Upgraded Node.js to version 18.16.1.
- Redis Node has an optional CA certificate field when attempting to connect over TLS.
- Array Node now supports the "Deduplicate" operation.
1.40.0 - 2023-06-13
Added
- OPC UA Triggers configuration fields can be pulled by name from the Edge Agent configuration file.
Changed
- Agent Config: Set Node allows setting OPC UA trigger configuration fields.
- Agent Config: Get Node includes any OPC UA trigger configurations that are set on the agent configuration file.
- Device: State Node uses the payload's time even if the workflow removes the
timepath from the payload. - AWS S3: Get and AWS S3: Put Nodes verify the region is provided and is valid.
- Upgraded Debian to version 12 ("bookworm").
1.39.0 - 2023-05-11
Added
- ✨ New Data / Siemens S7: Write Node.
- ✨ New Data / Siemens S7: Read Node.
- ✨ New Output / Azure: Event Hubs Node.
- ✨ New Output / Particle Call Node.
- ✨ New Output / GCP Pub/Sub Node.
- ✨ New Output / AWS SQS Node.
- ✨ New Triggers / Application: Sync Trigger.
developversions of workflows can now be deployed to a single device for ease of testing.
Changed
- Upgraded Node.js to version 18.16.0.
- Upgraded Alpine Docker image to 3.17.
- Function Node
console.logmessages log out all arguments given to the console function.
Fixed
- MongoDB Node no longer requires the
optionsargument for theupdateorremoveoperations. - MongoDB Node correctly handles Date object transformation into BSON Date types.
1.38.0 - 2023-03-30
Added
- ✨ New Data / Loggly: Write Node.
Changed
- Upgraded Node.js to version 18.15.0.
- Redis Node supports connecting to a Redis instance running in cluster mode.
- Debug Node supports setting a debug level.
Fixed
- Time Range Node properly handles comparisons when start time is greater than end time.
- GCP: BigQuery Node is consistent about configuration for delete actions, when delete all tables in the dataset is unchanged.
- JWT: Decode Node does not throw errors when attempting to decode a corrupted token.
1.37.0 - 2023-02-21
Added
OFFLINE_MESSAGE_REPLAY_ORDER, which can be set to eitheroldestFirstornewestFirst. This controls the order in which to send queued messages to Losant after reconnecting. Defaults tooldestFirst.
Changed
- Upgraded Node.js to version 18.14.1.
- GCP: Function Node accepts second-generation URLs for the
Trigger URL Template. - Validate Payload Node does not allow regular expressions with lookaheads.
1.36.1 - 2023-01-24
Fixed
- Alpine versions of the
1.36.0agent had a misconfiguration that prevented them from starting.
1.36.0 - 2023-01-17
Changed
- The agent has been upgraded to ECMAScript modules instead of using CommonJS.
- Upgraded Node.js to version 18.12.1.
- Upgraded Debian to version 11 ("bullseye").
Fixed
applicationIdandapplicationNameon initial workflow payloads no longer unexpectedly revert to incorrect values.{{defaultTo}} Handlebars helperuses its default value when a sub-expression returnsundefined.
1.35.0 - 2022-11-30
Added
- Redis Node now allows the following commands:
bitfield_ro,expiretime,fcall,fcall_ro,georadius_ro,georadiusbymember_ro,lcs,pexpiretime,sintercard,sort_ro,spublish,zintercard. - ✨ New Handlebars helper functions:
{{ceil}},{{titleCase}},{{jsonDecode}},{{array}},{{merge}},{{indexByKey}},{{floor}}.
Changed
- Redis Node accepts a payload path to use as arguments.
- Redis Node accepts an error path; when provided, a Redis error will be added to the payload instead of erroring the entire workflow.
{{#each}}Handlebars block helper can now iterate over numbers and strings.{{valueByKey}} Handlebars helpersupports payload paths.- Upgraded Node.js to version 16.18.1.
Fixed
- GCP: Function Node validates the authentication credentials when provided as a payload path.
- CSV: Encode Node drops any falsy rows that were included in the CSV source payload path.
- Handlebars
{{#each}}helper's@lastproperty returnstrueif this is the last element in the loop.
1.34.0 - 2022-10-12
Changed
- Validate Payload Node now returns as many errors as possible instead of just the first error.
subscribeToPeripheralUpdatesnow allows controlling if only floating or only static peripheral updates should be subscribed to, by adding two new possible options for the configuration field:floatingandperipheral.- Upgraded Node.js to version 16.17.1.
- Upgraded Alpine Docker image to 3.16.
Fixed
- Local MQTT broker no longer instantiates when the broker is disabled.
- Agent will now resubscribe to custom topics after multiple disconnect/reconnect cycles.
1.33.0 - 2022-09-06
Added
- ✨ New Data / GCP Storage: Get Node.
- ✨ New Data / GCP Storage: Put Node.
- Edge workflow payloads now have the
devicefield, whose value represents the edge compute device.
Changed
- Peripheral: Get Node now supports returning attributes as an object map and tags as an array.
- Improved redaction of potentially sensitive values in debug payload messages.
- Upgraded Node.js to version 16.17.0.
1.32.0 - 2022-07-26
Added
- The last Handlebars helper was added.
Changed
- Hash Node now supports setting the encoding for the secret and data inputs.
- Upgraded Node.js to version 16.16.0.
Fixed
- SNMP: Write Node now casts the values being written to the expected types when possible.
1.31.0 - 2022-06-14
Added
- ✨ New Data / Azure Blob: Get Node.
- ✨ New Data / Azure Blob: Put Node.
- The Edge Agent version is now exposed as the field
agentVersionon workflow payloads.
Changed
- JWT: Create Node now supports adding custom header fields.
- Upgraded Node.js to version 16.15.1.
- Upgraded Alpine Docker image to 3.15.
1.30.0 - 2022-05-10
Added
- Object Node now supports the "Zip Object" operation.
- HTTP Node now supports body types multipart/form-data and application/x-www-form-urlencoded.
Changed
- Upgraded Node.js to version 16.15.0.
- Function Node allows for passing an optional scope path. When provided, only that part of the payload is accessible to the node instead of the entire payload.
1.29.0 - 2022-04-05
Changed
- Upgraded Node.js to version 16.14.2.
- MQTT Trigger allows for triggering based on wildcard topics from the Losant Broker.
Fixed
- BACnet: Write and BACnet: Read Nodes set the APDU timeout field to the value or template given on the node. When left blank, the value defaults to the
MAX_EXTERNAL_CALL_TIMEenvironment variable. TheMAX_EXTERNAL_CALL_TIMEdefaults to 30 seconds. - BACnet: Read Node always casts each instruction key field to a string.
1.28.0 - 2022-03-01
Changed
- Upgraded Node.js to version 16.14.0.
Fixed
- Modbus: Write and Modbus: Read Nodes allow unit ID to be set to 0.
1.27.0 - 2022-01-25
Added
- ✨ New Data / FTP: Get Node.
- ✨ New Data / FTP: Put Node.
- ✨ New Triggers / SNMP: Trap Trigger.
Changed
- Upgraded Node.js to version 16.13.2.
Fixed
- OPCUA: Browse Node ensures there are no duplicate entries when browsing directories or objects.
1.26.0 - 2021-12-09
Changed
- Upgraded Node.js to version 16.13.0.
- Upgraded Debian to version 10 ("buster").
Fixed
- Data / SNMP Write Node gives correct type in error messages for arguments when type is incorrect.
1.25.0 - 2021-10-21
Added
- Data / BACnet: Who-Is
Changed
- Upgraded Node.js to version 14.18.0.
- More specific error messages when on disk workflows fail to load.
- Triggers / Workflow Error Trigger payloads now contain a reply ID to use for an HTTP Response if a critical error comes after an HTTP Request Trigger.
1.24.0 - 2021-08-24
Added
- Data / Agent Config: Set Node
- The HTTP Request Trigger can now optionally be configured to only match specific methods and routes.
Changed
- Upgraded Node.js to version 14.17.5.
- The ability to turn off subscribing to peripheral updates is now exposed through the configuration setting
subscribeToPeripheralUpdates. - The agent now responds to the signal
SIGHUP, which will trigger a reload of the on-disk configuration. - Debug messages now include workflow node timing information.
Fixed
- The agent now correctly supports SNI when connecting to brokers over TLS.
- Modbus client race conditions during shutdown, which sometimes led to errors, have been fixed.
1.23.0 - 2021-07-19
Added
- Data / Agent Config: Get Node
- Data / Losant API Node
- Data / SNMP: Get Subtree Node
- Data / SNMP: Read Node
- Data / SNMP: Write Node
- The AWS S3: Put Node can now upload a file directly from a URL.
- The Redis Node supports a number of new Redis 6 commands, and supports username authentication.
- The Array Node now supports the
keyByoperation. - The evalExpression Handlebars helper was added.
- Workflows can now be loaded and run from exported on-disk files.
Changed
- Upgraded Node.js to version 14.17.0.
- Upgraded Alpine Docker image to 3.13.
MQTT_KEEPALIVEis now exposed as an advanced option.- A Device ID and Losant Broker credentials are no longer required to start the agent. The agent will run without a broker connection when these are not provided.
Fixed
- Fixed an issue where the Object Node could error on poor input to the
fromPairsoperation.
1.22.1 - 2021-06-01
Fixed
- Fixed an issue where the Function and Loop nodes did not correctly use the value from the environment variable
MAX_FLOW_RUN_TIMEand instead continued to use the default value.
1.22.0 - 2021-05-26
Added
- GCP: Function Node now supports HTTP triggered invocations.
Changed
- Upgraded Node.js to version 14.16.1.
- Modbus Read Node and Modbus Write Node share client connections and keep frequently used clients open.
- Allen-Bradley Read Node and Allen-Bradley Write Node return errors with the key to the specific instruction that caused the error.
Fixed
- If the store path from the configuration points to a corrupted database, the Gateway Edge Agent will now copy those files into a separate directory and create a new database at that given path.
- BACnet Read Node and BACnet Write Node will now properly validate Host Port Template and Incoming Port Template.
- Modbus Read Node and Modbus Write Node when closing a connection the nodes wait until the connection is completely closed.
- Allen-Bradley Read Node now defaults reads of data type "STRING" to an empty string if the tag is undefined.
1.21.0 - 2021-03-30
Added
- Array Node - Added slice operation.
- Loop Node - Added a new field "Loop Mode" which allows the loop to run either in parallel or serially (the default). In addition, added the ability for the Loop Node to build an array of the result of each iteration.
Changed
- Upgraded Node.js to version 14.16.0.
Fixed
- Twitter Node - catching and wrapping up malformed errors from the Twitter API, and defaulting an error message when one cannot be found.
- Loop Node - All loop node lists are populated correctly no matter the type of source.
1.20.1 - 2021-02-24
Changed
Fixed
- Modbus Read Node - Fixed setting the results to an instruction to the wrong key after a timeout error.
- Modbus Write Node - Fixed setting the results to an instruction to the wrong key after a timeout error.
1.20.0 - 2020-12-15
Added
- Installing bash on Alpine images.
Changed
- BACnet Read Node and BACnet Write Node will now cache the connected clients to be reused on the Gateway Edge Agent.
Fixed
Validating hosts when using the following nodes:
- Modbus Read Node
- Modbus Write Node
- Allen-Bradley Write Node
- OPC UA Read Node
- OPC UA Write Node.
1.19.2 - 2020-10-21
Added
- Allen-Bradley: Read and Allen-Bradley: Write Nodes can receive instructions defined through a payload path.
Changed
- Updated serial connections for the following nodes to allow baud rate to be any positive integer: Serial Trigger, Serial Write Node, Modbus Write Node, and Modbus Read Node.
- The Serial Trigger has new configuration fields: Delimiter Encoding and Write On Open Encoding.
- Updated the UDP Send Node to enable destination addresses to be broadcast addresses.
- Upgraded underlying libraries for the OPC UA trigger and nodes.
Fixed
- Fixed Serial Write Node issue where the configured write encoding was not used.
1.19.1 - 2020-09-25
Changed
- Idle client and session cleanup behavior for the OPC UA Nodes has been changed to be more robust and consistent.
- Expose new environment variables to control idle cleanup behavior for the OPC UA Nodes.
Fixed
- Fixed race condition on session creation for OPC UA Nodes.
- Fixed race condition on session and client disposal for OPC UA Nodes.
- Fixed issue where the configured Security Policy was not correctly used for OPC UA Nodes.
- Fixed issue where OPC UA subscriptions where not disposed on OPC UA trigger removal.
1.19.0 - 2020-09-08
Added
- Data / BACnet Read Node
- Data / BACnet Write Node
Changed
- Serial Trigger new configuration fields: Parity, Stop Bits, Data Bits, RTSCTS.
- Serial Write Node new configuration fields: Parity, Stop Bits, Data Bits, RTSCTS.
Fixed
- Agent no longer waits for On Startup workflows to complete before connecting to Losant.
- Modbus Read Node function "Read Device Identification" now works properly over RTU Serial.
- OPC UA Browse Node, OPC UA Call Node, OPC UA Read Node and OPC UA Write Node now handles an Invalid Secure Channel error properly.
- CSV: Encode Node no longer mutates the row entry when passing as an array from the payload.
- Agent now attaches signal handlers for SIGINT / SIGTERM before the Gateway Edge Agent is up and running.
1.18.2 - 2020-08-10
Fixed
- Fix issue where under certain circumstances the SQL Node for MySQL would return incorrect results on select statements.
1.18.1 - 2020-07-23
Changed
- Upgraded Node.js to version 12.18.0.
- Changed MQTT reconnect interval to be variable, defaults to 30 seconds +/- 15 seconds
1.18.0 - 2020-06-11
Changed
- Added support for payload path configuration for the OPC UA Browse, Call, Read, and Write nodes.
- Upgraded the underlying libraries for the Tensorflow: Predict node.
- Messages published to the Losant cloud broker by the Device: State and MQTT nodes now check to make sure they are below the maximum allowed size.
- Added support for the stream commands to the Redis node.
- Added an optional result path to the Tweet node.
- Added an optional result path to the Slack node.
Fixed
- Fix issue where under certain circumstances the Tensorflow: Predict node could crash the agent.
- Fix issue where host clock changes were not correctly taken into account for the Timer trigger.
- Fix issue where the Tensorflow: Predict node no longer worked on the
arm32build of the agent. - Fix issue where the HTTP node did not properly obey the
MAX_EXTERNAL_CALL_TIMEenvironment variable. - Fix some rare timeout race conditions in the Function node.
1.17.0 - 2020-04-28
Added
- Added support for using the Gateway Edge Agent as a local MQTT Broker.
Changed
- Added the ability for the MQTT Trigger to trigger on messages published to the local broker.
- Added the ability for the MQTT Node to publish messages to the local broker.
- Added support for the server-side encryption flag to the AWS S3: Put Node.
1.16.0 - 2020-03-18
Added
- Data / Peripheral: Get
Changed
- Added support for Read Device Identification to the Modbus: Read node.
- Upgraded Node.js to version 12.16.1.
Fixed
- Fix issue where under certain circumstances the Run Executable node could crash the agent.
- Fix issue where the Workflow Error trigger could crash the agent when the payload was in certain unexpected formats.
1.15.0 - 2020-02-19
Changed
- Upgraded underlying libraries for the Modbus: Read and Modbus: Write nodes.
- Upgraded underlying libraries for the Serial Write node and the Serial trigger.
- Upgraded underlying libraries for the MongoDB node.
- Added support for an error path to the MongoDB node.
- Added support for replaceOne and aggregate to the MongoDB node.
Fixed
- Re-enable support for TLS 1.0 and 1.1 in the HTTP node (was removed in previous version).
1.14.0 - 2020-01-10
Changed
- Upgraded Node.js to version 12.13.0.
- Added support for an error path to the JSON Decode node.
Fixed
- Fix issue where an error in a Function node could crash the agent.
1.13.0 - 2019-11-07
Added
- Trigger / Workflow Error
Changed
- Added support for fractional second timers to the Timer trigger.
- Add new options and timezone support to the Date/Time node.
- Improved performance of the Function node for large payloads.
- Upgraded underlying libraries for the SQL node.
1.12.0 - 2019-10-07
Added
- Trigger / File Tail
Changed
- Added ability to see result information for the Device: State node.
Fixed
- Fix issue where agent would incorrectly think the current architecture would support the TensorFlow: Predict node, and the agent would crash.
1.11.0 - 2019-08-22
Added
- Trigger / Device: Connect
- Trigger / Device: Disconnect
- Trigger / Device: Startup
- Logic / Date / Time
- Data / GCP: Function
Changed
- Changed the default parse method for the Serial trigger to be delimiter instead of byte length.
- Add ability to define data bits, stop bits, and parity for the Modbus: Read and Modbus: Write nodes when connecting with serial.
- Upgraded Node.js to version 10.16.0.
Fixed
- Fix issue where unit id was improperly ignored for the Modbus: Read and Modbus: Write nodes when connecting with serial.
- Fix race condition where agent could crash when workflow debugging was enabled and workflows were triggered immediately on startup.
- Fix issue where agent could error when cleaning up stale TensorFlow: Predict models.
1.10.0 - 2019-07-23
Added
- Data / Azure: Function
- Data / TensorFlow: Predict
Changed
- Added support for serial RTU connections for the Modbus: Read node.
- Added support for serial RTU connections for the Modbus: Write node.
- Added support to get all storage values with the Storage: Get Value node.
- Upgraded the underlying libraries for the various OPC UA nodes.
- Workflow storage writes now write to disk asynchronously every few seconds and do not block the running workflow.
- Deprecated
timeSincePathsupport for the Throttle node.
Fixed
- Fix typos in OPC UA node error messages.
- Fix issue where the Allen-Bradley Read and Write nodes would behave inconsistently when controller and tag names were the same.
- Fix issue where heavy use of the Throttle node would cause errors.
1.9.1 - 2019-06-13
Fixed
- Fixed race condition introduced in 1.9.0 that would cause the agent to crash on startup in certain circumstances.
1.9.0 - 2019-06-06
Added
- Data / OPC UA: Read
- Triggers / OPC UA
Changed
- Added support for configuration via a payload path for the Modbus: Read node.
- Added support for configuration via a payload path for the Modbus: Write node.
- Added support for FC16 writes in the Modbus: Write node.
- Added SSL support to the Redis node.
- The HTTP node now supports a request body encoding type.
- The String node now supports
pad. - Upgraded Node.js to version 10.15.3.
Fixed
- Fixed Buffer, Date, and ObjectID type inconsistencies when passing data to and from the Function node.
- Fixed issue where multiline statements did not work properly in the SQL node.
- Fixed issue with the Postgres
Intervaldata type in results from the SQL node.
1.8.0 - 2019-04-24
Added
- Data / AWS S3: Get
- Data / AWS S3: Put
Changed
- Improved error messages when evaluating expressions with incorrect use of the
!operator. - Improved error messages for the Generate ID node.
- The HTTP Node now supports a response body encoding type.
Fixed
- Fixed issue where OPC UA nodes errored the workflow instead of adding an error to the payload when the OPC UA call returned an invalid datatype.
jsonEncodepayload helper behaved incorrectly when used recursively.
1.7.0 - 2019-03-26
Added
- Data / Serial Write
Fixed
- Fixed issue with OPC UA nodes not correctly reusing the same session across workflow runs.
- Fixed issue where workflows allowed invalid program and tag names for the Allen-Bradley nodes.
1.6.1 - 2019-02-28
Fixed
- Fixed a permissions issue with the Docker image which caused filesystem permission errors with the OPC UA nodes.
1.6.0 - 2019-02-27
Added
- Triggers / Serial
- Data / OPC UA: Write
- Data / OPC UA: Browse
- Logic / CSV: Decode
- Logic / CSV: Encode
Fixed
- Fixed an issue where non-geographic area codes for USA phone numbers were rejected as invalid in the Twilio node.
1.5.0 - 2019-01-31
Added
- Triggers / Redis
- Triggers / Virtual Button
- Data / SQL
Changed
- The HTTP Node now supports making requests with client certificates.
- The HTTP Node now supports using a custom CA.
- Upgraded Node.js to version 10.15.0.
Fixed
- Fixed an issue where one workflow could monopolize the process and prevent other workflows from running.
1.4.0 - 2018-12-18
Added
- Data / Allen-Bradley: Read
- Data / Allen-Bradley: Write
1.3.1 - 2018-11-21
Fixed
- Fixed an issue where a mix of successful and failing modbus reads in a single Modbus: Read node would not be represented correctly on the payload.
- Fixed an issue with the MongoDB where certain connection URIs were incorrectly parsed.
1.3.0 - 2018-11-08
Added
- Triggers / File Watch
Changed
- The Modbus: Write Node now has an adjustable timeout.
- The Modbus: Read Node now can be configured to read values as either signed or unsigned, and it has an adjustable timeout.
Fixed
- An issue where using the
currentDateTimetemplate helper by itself without a format argument would result in a blank string has been fixed. - An issue where the agent would exit without waiting for logs to finish writing has been fixed.
- An issue with timers configured by cron in certain timezones would hang has been fixed.
1.2.5 - 2018-10-04
Fixed
- The File: Read Node now correctly closes the open file handle afterward in all cases.
- When the File: Read Node errors, it no longer overwrites the entire payload with the error message in certain cases.
- The Modbus: Write Node now correctly accepts the full range of a 16 bit unsigned integer for writing to a register.
1.2.4 - 2018-09-28
Changed
- Change the limit on the number of concurrently running nodes to be applied per running workflow instead of globally across all running workflows.
1.2.3 - 2018-09-27
Added
- There are now Alpine-based Docker images for the Gateway Edge Agent.
- The typeof Handlebars helper has been added.
Changed
- The Run Executable Node now supports detaching from the executable.
- The Geofence Node now supports drawing custom polygons.
- The Array Node now supports concat.
- Upgraded Node.js to version 8.12.0.
Fixed
- The HTTP Node now uses
autoforecdhCurvefor SSL connections.
1.2.2 - 2018-08-22
Added
- Added a configuration flag to control the queuing of messages while the agent is offline.
- Added the new payload helper
scaleLinear. - Added the new payload helper
currentDateTime.
Changed
- Improved Google Big Query and GoogleML Node error handling.
- Clarified certain verbose log messages.
1.2.1 - 2018-08-07
Added
- Can now choose to have no expiration time for the JWT: Create Node.
Changed
- Modbus: Read Node and Modbus: Write Node now default to port 502.
- Improved MongoDB Node error handling.
- A workflow publishing MQTT messages to an invalid or unauthorized topic will no longer cause the agent to disconnect from the Losant Platform.
Fixed
- System clock changes no longer affect the firing of interval timers while the agent is running.
- Debug messages with circular references correctly send to the Losant Platform.
1.2.0 - 2018-06-21
Added
- Data / ServiceNow Node
- Triggers / UDP Trigger
- Outputs / UDP Send Node
- Edge workflow payloads now have environment variables available under the field
agentEnvironment. - Edge workflow payloads now have the field
isConnectedToLosant, representing if the agent is currently connected to Losant.
Changed
- Easily set authorization headers for requests on the HTTP Node.
- Can now set the path for a cookie on the HTTP Response Node.
- Improved phone number casting for the Twilio Node.
- Upgraded Node.js to version 8.11.3.
1.1.1 - 2018-05-21
Changed
- Improved startup messages.
- The HTTP Node now allows for setting timeouts and capturing network errors.
Fixed
- Improved messages for Slack Node errors.
- Support circular references in debug messages.
1.1.0 - 2018-03-29
Added
- Logic / Generate ID Node
- Logic / Hash Node
Changed
- The Validate Payload Node now allows for defining your schema using either a payload path or a JSON template.
Fixed
- Modbus: Read Node's "Length" property now defaults to a value of 1 if left blank.
- Modbus: Read and Modbus: Write Nodes will now time out if they fail to connect to Modbus.
1.0.0 - 2018-03-08
Added
- Triggers / Timer Trigger
- Triggers / HTTP Request Trigger
- Triggers / MQTT Trigger
- Triggers / Device: Command Trigger
- Data / Modbus: Read Node
- Data / Modbus: Write Node
- Data / File: Read Node
- Data / File: Write Node
- Data / Run Executable Node
- Outputs / HTTP Response Node
