List of Workflow Nodes
Below is a list of all workflow nodes available in Losant’s cloud platform, in the Gateway Edge Agent, and in the Embedded Edge Agent. To learn more about a node, click its name to view detailed documentation and examples.
Triggers​
  • Amazon SQS Trigger
    The Amazon SQS Trigger fires a workflow whenever a Losant integration receives an Amazon Simple Queue Service (SQS) message.
  • Application: Sync Trigger
    The Application: Sync Trigger fires a workflow whenever the Gateway Edge Agent receives updated peripherals, global values, or changes to its Edge Compute device configuration.
  • Azure Event Hubs Trigger
    The Azure Event Hubs Trigger fires a workflow whenever a Losant integration receives an Azure Event Hubs message.
  • Beckhoff Trigger
    The Beckhoff Trigger fires a workflow whenever monitored symbols on a Beckhoff TwinCAT PLC receive new values.
  • Data Table Trigger
    The Data Table Trigger fires a workflow whenever a row is added, updated, or removed from a Losant Data Table.
  • Device: Command Trigger
    The Device: Command Trigger fires a workflow whenever its Edge Compute or Embedded Device receives a command over the MQTT broker.
  • Device: Connect Trigger
    The Device: Connect Trigger fires a workflow whenever one or more devices connect to the Losant Platform.
  • Device: Create Trigger Node
    The Device: Create Trigger fires a workflow whenever a device is created within your application.
  • Device: Disconnect Trigger
    The Device: Disconnect Trigger fires a workflow whenever one or more devices disconnect from the Losant Platform.
  • Device: Inactive Trigger
    The Device: Inactive Trigger fires a workflow whenever one or more devices do not report state for the configured period of time.
  • Device: Startup Trigger
    The Device: Startup Trigger fires a workflow whenever the Gateway Edge Agent starts or restarts.
  • Device: State Trigger
    The Device: State Trigger fires a workflow whenever a device reports state to the Losant cloud platform.
  • Direct Trigger
    The Direct Trigger fires an Embedded Workflow whenever the "eea_direct_trigger" method is invoked within the Embedded Edge Agent.
  • EEA: Init Trigger
    The EEA: Init Trigger fires a workflow whenever the "eea_init" function is called within the Embedded Edge Agent.
  • Email Trigger
    The Email Trigger fires a workflow whenever your application receives an email at its address or a subaddress.
  • Endpoint Trigger
    The Endpoint Trigger fires a workflow when the selected Experience Endpoint receives an HTTP request.
  • Event Trigger
    The Event Trigger fires a workflow whenever an event matching the criteria defined in the trigger's configuration is created or changes state.
  • File Tail Trigger
    The File Tail Trigger allows you to monitor and analyze logs and other files on the Gateway Edge Agent's container or host file system.
  • File Watch Trigger
    The File Watch Trigger fires a workflow whenever the file or directory changes are observed on the Gateway Edge Agent.
  • File Trigger
    The File Trigger allows you to fire a workflow when a file is created, modified, or deleted from a directory in your Application Files.
  • GCP Pub/Sub Trigger
    The GCP Pub/Sub Trigger fires a workflow whenever a message is sent to a Losant GCP Pub/Sub integration.
  • HTTP Request Trigger
    The HTTP Request Trigger fires a workflow whenever the Gateway Edge Agent receives a request on its local web server.
  • Job: Complete Trigger
    The Job: Complete Trigger fires a workflow whenever a Resource Job completes all iterations or is canceled during execution.
  • Job: Timeout Trigger
    The Job: Iteration Timeout Trigger fires a workflow whenever an iteration of a Resource Job is not acknowledged before the Resource Job’s configured timeout.
  • Job: Iteration Trigger
    The Job: Iteration Trigger fires a workflow whenever an iteration of a Resource Job begins.
  • MQTT Trigger
    The MQTT Trigger fires a workflow whenever a message is published to a topic on the Losant MQTT Broker, the Gateway Edge Agent Local Broker, an external broker, or an MQTT integration.
  • Notebook Trigger
    The Notebook Trigger fires a workflow whenever the selected Losant Notebook has completed an execution, either successfully or with errors.
  • OPC UA Trigger
    The OPC UA Trigger fires a workflow whenever an Edge Compute Device receives a change message on the configured OPC UA monitored node.
  • Particle Trigger
    The Particle Trigger fires a workflow whenever an event is received on the Losant Particle integration.
  • Redis Trigger
    The Redis Trigger fires a workflow whenever the Edge Compute Device receives a message on the configured Redis Pub/Sub channel.
  • Serial Trigger
    The Serial Trigger fires a workflow whenever the Edge Compute Device receives data over a Serial connection.
  • SNMP Trap: Trigger
    The SNMP: Trap Trigger fires a workflow whenever the Edge Compute Device receives an SNMP trap message or an SNMP inform request.
  • Timer Trigger
    The Timer Trigger fires a workflow on a scheduled interval.
  • UDP Message Trigger
    The UDP Message Trigger fires a workflow whenever the Edge Compute Device receives a UDP datagram on the configured port.
  • Virtual Button Trigger
    The Virtual Button Trigger fires a workflow when the "virtual button" is pressed.
  • Webhook Trigger
    The Webhook Trigger fires a workflow whenever a Losant webhook receives an HTTP request or WebSocket message.
  • WebSocket Trigger
    The WebSocket Trigger fires a workflow whenever a Losant WebSocket integration receives a message.
  • Workflow Error Trigger
    The Workflow Error Trigger fires a workflow whenever a halting error occurs in a separate workflow execution.
Debugging Nodes​
  • Debug Node
    The Debug Node prints out the current payload and execution timing info at the point of invocation within a workflow run.
  • Throw Error Node
    The Throw Error Node halts a workflow execution, logs the provided error message, and fires any associated Workflow Error Triggers.
Experience Nodes​
  • Authenticate Experience User Node
    The Authenticate Experience User Node authenticates an email and password against Experience Users in a Losant application.
  • Device: Verify Node
    The Device: Verify Node checks whether a given device is associated with an Experience Group or Experience User in a Losant application.
  • Generate Experience User Token Node
    The Generate Experience User Token Node creates a token for an Experience User to make authorized requests against Experience Endpoints.
  • Group: Create Node
    The Group: Create Node adds a new Experience Group to a Losant application.
  • Group: Get Node
    The Group: Get Node retrieves one or more Experience Groups from a Losant application.
  • Group: Summary Node
    The Group: Summary Node retrieves Experience Groups in a hierarchical tree format.
  • Group: Update Node
    The Group: Update Node updates an existing Experience Group within a Losant application.
  • Group: Verify Node
    The Group: Verify Node checks whether a given Experience User is a member of an Experience Group or any of the group's children.
  • SAML: Login URL Node
    The SAML: Login URL Node creates a login URL for a Security Assertion Markup Language 2.0 (SAML) single sign-on (SSO) identity provider.
  • SAML: Verify Node
    The SAML: Verify Node verifies and extracts response data from a Security Assertion Markup Language 2.0 (SAML) single sign-on (SSO) identity provider.
  • User: Create Node
    The User: Create Node adds a new Experience User to a Losant application.
  • User: Delete Node
    The User: Delete Node removes an Experience User from a Losant application.
  • User: Get Node
    The User: Get Node retrieves one or more Experience Users from a Losant application.
  • User: Update Node
    The User: Update Node updates an existing Experience User within a Losant application.
Logic Nodes​
  • Array Node
    The Array Node performs operations against an array-type value on the payload.
  • Base64: Decode Node
    The Base64: Decode Node takes a Base64-encoded string and decodes it as a binary array.
  • Base64: Encode Node
    The Base64: Encode Node takes a string or binary array and encodes it to a Base64 string.
  • CBOR: Decode Node
    The CBOR: Decode Node takes a CBOR-encoded value and parses it into an object.
  • CBOR: Encode Node
    The CBOR: Encode Node takes an object and converts it into Concise Binary Object Representation format.
  • Certificate: Create Node
    The Certificate: Create Node signs a Certificate Signing Request with the requester's public key and identity information and issues a new certificate.
  • Certificate: Read Node
    The Certificate: Read Node returns a given certificate's public key and metadata information.
  • Conditional Node
    The Conditional Node branches a workflow based on the result of an expression.
  • Crypto: Hash Node
    The Crypto: Hash Node creates a cryptographic hash through a variety of algorithms.
  • Crypto: Sign Node
    The Crypto: Sign Node generates an encrypted signature from a given key and string of data.
  • Crypto: Verify Node
    The Crypto: Verify Node verifies that a given signature matches the given certificate, public key or private key.
  • CSV: Decode Node
    The CSV: Decode takes a CSV string and decodes it into an object array.
  • CSV: Encode Node
    The CSV: Encode Node takes an object array and encodes it into a CSV string.
  • Date/Time Node
    The Date/Time Node allows for parsing and manipulating dates and timestamps.
  • Delay Node
    The Delay Node pauses a workflow execution for a short period of time.
  • Fast Fourier Transform Node
    The Fast Fourier Transform Node takes an array of data points from one domain and converts it into a frequency representation using a fast Fourier transform algorithm.
  • Function Node
    The Function Node allows execution of arbitrary, user-defined JavaScript.
  • Generate ID Node
    The Generate ID Node creates IDs in UUID, Object ID, or Nano ID format.
  • Geofence Node
    The Geofence Node branches a workflow based on whether a given geographic point is within a defined area.
  • HTML/XML Parser Node
    The HTML/XML Parser Node takes an HTML or XML document string and parses it into a traversable tree.
  • JSON: Decode Node
    The JSON: Decode Node takes a JSON string and parses it into an object.
  • JSON: Encode Node
    The JSON: Encode Node takes an object and converts it into a JSON string.
  • JWT: Create Node
    The JWT: Create Node generates a JSON Web Token from a JSON payload, optional headers, and a secret.
  • JWT: Decode Node
    The JWT: Decode Node takes a JSON Web Token and decodes it to an object.
  • JWT: Verify Node
    The JWT: Verify Node branches a workflow based on whether a provided JSON Web Token is valid.
  • Latch Node
    The Latch Node allows for easy "one-time" branching of a workflow, with the ability to reset the branch condition.
  • Loop Node
    The Loop Node allows for iterating over values on your payload, or for performing a certain operation a set number of times.
  • Math Node
    The Math Node performs expression-based mathematical calculations.
  • Mutate Node
    The Mutate Node modifies, moves, copies, or removes values from a workflow payload.
  • Object Node
    The Object Node performs operations against objects or arrays on the payload.
  • On Change Node
    The On Change Node branches a workflow based on whether a value has changed since previous executions of the workflow.
  • Random Number Node
    The Random Number Node generates a random integer within a range of your choosing.
  • Root Mean Square Node
    The Root Mean Square Node calculates the root mean square (RMS) of an array of numbers.
  • Rust Function Node
    The Rust Function Node allows for execution of user-defined Rust code.
  • String Node
    The String Node allows for manipulating string values.
  • Switch Node
    The Switch Node branches across many different paths based on matching a switch statement against various case values.
  • Throttle Node
    The Throttle Node branches a workflow based on the amount of time that has passed since the last execution of the node.
  • Time Range Node
    The Time Range Node branches based on whether a given timestamp is within a provided time range.
  • Validate Payload Node
    The Validate Payload Node branches a workflow based on whether a given value validates against a provided JSON schema.
  • YAML: Decode Node
    The YAML: Decode Node takes a YAML string and parses it into an object.
  • YAML: Encode Node
    The YAML: Encode Node takes an object and converts it into a YAML string.
Data Nodes​
  • Access Key: Create Node
    The Access Key: Create Node generates a new Access Key for authenticating against the Losant MQTT Broker.
  • Agent Config: Get Node
    The Agent Config: Get Node retrieves configuration settings for an instance of the Gateway Edge Agent.
  • Agent Config: Set Node
    The Agent Config: Set Node changes configuration settings for an instance of the Gateway Edge Agent.
  • Allen-Bradley: Read Node
    The Allen-Bradley: Read Node reads multiple tags from an Allen-Bradley CompactLogix or ControlLogix programmable logic controller (PLC).
  • Allen-Bradley: Write Node
    The Allen-Bradley: Write Node writes to multiple tags on an Allen-Bradley CompactLogix or ControlLogix programmable logic controller (PLC).
  • AWS Lambda Node
    The AWS: Lambda Node executes an AWS Lambda function and optionally returns the result.
  • AWS S3: Get Node
    The AWS S3: Get Node retrieves a file and its metadata from an Amazon S3 bucket.
  • AWS S3: Put Node
    The AWS S3: Put Node uploads a file into an Amazon S3 bucket.
  • Azure Blob: Get Node
    The Azure Blob: Get Node retrieves a file and its metadata from an Azure Blob Storage container.
  • Azure Blob: Put Node
    The Azure Blob: Put Node uploads a file to an Azure Blob Storage container.
  • Azure: Function Node
    The Azure: Function Node executes an Azure Function and optionally returns the result.
  • Azure: Table Storage Node
    The Azure: Table Storage Node allows you to perform entity operations on an Azure Data Table.
  • BACnet: Read Node
    The BACnet: Read Node reads multiple properties across multiple objects from a BACnet device.
  • BACnet: Who-Is Node
    The BACnet: Who-Is Node broadcasts a Who-Is message and awaits I-Am replies from BACnet-compatible devices on a network.
  • BACnet: Write Node
    The BACnet: Write Node writes multiple properties in multiple objects on a BACnet device.
  • Beckhoff: Read Node
    The Beckhoff: Read Node reads multiple symbol values from a Beckhoff TwinCAT PLC.
  • Beckhoff: Write Node
    The Beckhoff: Write Node allows for writing values to one or more symbols on a Beckhoff TwinCAT PLC.
  • Data: Gauge Query Node
    The Data: Gauge Query Node retrieves aggregate state data for one or more attributes across one or more devices.
  • Data: Time Series Node
    The Data: Time Series Node retrieves state data across a time period for one or more attributes across one or more devices.
  • Datadog Logs: Write Node
    The Datadog Logs: Write Node sends one or more messages to a Datadog instance.
  • Device Certificate: Register Node
    The Device Certificate: Register Node registers a new device certificate for authenticating against the Losant MQTT Broker.
  • Device: Create Node
    The Device: Create Node adds a new device to a Losant application.
  • Device: Delete Node
    The Device: Delete Node removes one or more devices from a Losant application.
  • Device: Get Node
    The Device: Get Node retrieves one or more devices from a Losant application.
  • Device: Update Node
    The Device: Update Node updates an existing device within a Losant application.
  • Edge: Deploy Node
    The Edge: Deploy Node schedules deployment of Edge Workflows to Edge Compute Devices.
  • Event: Create Node
    The Event: Create Node generates a new event within a Losant application.
  • Event: Delete Node
    The Event: Delete Node removes one or more events from a Losant application.
  • Event: Get Node
    The Event: Get Node retrieves one or more events from a Losant application.
  • Event: Update Node
    The Event: Update Node updates one or more existing events within a Losant application.
  • File: Create Node
    The File: Create Node creates a file within a Losant application's files.
  • File: Get Node
    The File: Get Node retrieves a Losant Application File, including its meta information and either its contents or a URL to download the contents.
  • File: Read Node
    The File: Read Node retrieves a file from disk on an Edge Compute Device.
  • File: Write Node
    The File: Write Node writes a file to disk on an Edge Compute Device.
  • FTP: Get Node
    The FTP: Get Node retrieves a file from an FTP or SFTP server.
  • FTP: Put Node
    The FTP: Put Node uploads a file to an FTP or SFTP server.
  • GCP: BigQuery Node
    The GCP: BigQuery Node makes requests to a Google BigQuery table.
  • GCP Storage: Get Node
    The GCP Storage: Get Node retrieves a file and its metadata from a Google Cloud Storage bucket.
  • GCP Storage: Put Node
    The GCP Storage: Put Node uploads a file to a Google Cloud Storage bucket.
  • GCP: Function Node
    The GCP: Function Node executes a Google Cloud Function and optionally returns a result.
  • GCP ML Node
    The GCP: ML Node sends data to Google ML and retrieves predictions based on models in that service.
  • HTTP Node
    The HTTP Node makes arbitrary HTTP requests to third-party services.
  • Loggly: Write Node
    The Loggly: Write Node sends one or more messages to SolarWinds Loggly
  • Losant API Node
    The Losant API Node makes application-scoped requests against the Losant API.
  • Modbus: Read Node
    The Modbus: Read Node reads multiple registers from Modbus-enabled PLCs.
  • Modbus: Write Node
    The Modbus: Write Node writes to multiple registers on Modbus-enabled PLCs.
  • MongoDB Node
    The MongoDB Node runs queries against a MongoDB database.
  • OPC UA: Browse Node
    The OPC UA: Browse Node allows for browsing node folders on an OPC UA Server.
  • OPC UA: Call Node
    The OPC UA: Call Node calls a method on an object within an OPC UA Server and connected programmable logic controller (PLC).
  • OPC UA: Read Node
    The OPC UA: Read Node retrieves multiple node values from an OPC UA Server and connected programmable logic controller (PLC).
  • OPC UA: Write Node
    The OPC UA: Write Node writes multiple node values to an OPC UA Server and connected programmable logic controller (PLC).
  • Peripheral: Get Node
    The Peripheral: Get Node retrieves one or more of an Edge Compute Device's associated Peripheral Devices.
  • Redis Node
    The Redis Node queries or updates values in a Redis database.
  • Registered Function Node
    The Registered Function Node invokes a registered function defined on an Embedded Device.
  • Run Executable Node
    The Run Executable Node runs a script or process locally on an Edge Compute Device.
  • Salesforce Cases Node
    The Salesforce Cases Node accesses the Salesforce Service Cloud to create, read, update, or delete cases in their CRM platform.
  • Serial: Write Node
    The Serial: Write Node writes values to a specified serial port.
  • ServiceNow Node
    The ServiceNow Node creates, updates, and retrieves records from tables in the ServiceNow platform.
  • Siemens S7: Read Node
    The Siemens S7: Read Node allows you to read one or more values from a PLC that supports the Siemens S7 protocol.
  • Siemens S7: Write Node
    The Siemens S7: Write Node allows you to write one or more values to a PLC that supports the Siemens S7 protocol.
  • SNMP: Get Subtree Node
    The SNMP: Get Subtree Node reads values beneath a root OID on an SNMP device.
  • SNMP: Read Node
    The SNMP: Read Node reads values from multiple OIDs on an SNMP device.
  • SNMP: Write Node
    The SNMP: Write Node writes values to one or more OIDs on an SNMP device.
  • Snowflake Node
    The Snowflake Node allows for executing a SQL query against a Snowflake table.
  • SQL Node
    The SQL Node queries or updates values in an SQL database.
  • Storage: Get Value Node
    The Storage: Get Value Node retrieves a value set by a Storage: Set Value Node in a previous workflow execution.
  • Storage: Set Value Node
    The Storage: Set Value Node stores a value for use in a subsequent workflow execution.
  • Table: Delete Rows Node
    The Table: Delete Rows Node deletes one or more rows from a Losant Data Table.
  • Table: Get Rows Node
    The Table: Get Rows Node retrieves one or more rows from a Losant Data Table.
  • Table: Insert Rows Node
    The Table: Insert Row Node adds one or more new rows to a Losant Data Table.
  • Table: Update Row Node
    The Table: Update Row Node updates an existing row in a Losant Data Table.
  • TensorFlow: Predict Node
    The TensorFlow: Predict Node makes predictions against a pretrained TensorFlow model that has been loaded onto an Edge Compute Device.
Output Nodes​
  • Amazon SQS Node
    The Amazon SQS Node publishes a message to an Amazon SQS queue.
  • Azure Event Hubs Node
    The Azure Event Hubs Node publishes a message to an Azure Event Hub.
  • Device: Command Node
    The Device: Command Node sends a command to one or more devices connected to the Losant MQTT Broker.
  • Device: State Node
    The Device: State Node records telemetry data as attributes for a device.
  • Email Node
    The Email Node sends an email to one or more users through Losant's provided email delivery.
  • Experience Endpoint Reply Node
    The Endpoint Reply Node sends a response to an Experience Endpoint HTTP request.
  • GCP Pub/Sub Node
    The GCP (Google Cloud Platform) Pub/Sub Node publishes a message to a Google Pub/Sub topic.
  • Edge HTTP Response Node
    The HTTP Response Node sends a response to an HTTP request received by an Edge Compute Device's local web server.
  • HTTP Node
  • Job: Acknowledge Node
    The Job: Acknowledge Node marks an iteration of a Resource Job as a success or failure.
  • Job: Execute Node
    The Job: Execute Node requests an execution of one of your application’s Resource Jobs.
  • Mailgun Node
    The Mailgun Node sends emails through a given Mailgun account.
  • MQTT Node
    The MQTT Node publishes a message to the Losant MQTT Broker, the Gateway Edge Agent Local Broker, an external broker, or an MQTT integration.
  • Notebook: Execute Node
    The Notebook: Execute Node initiates an execution of a Losant Notebook.
  • Particle Device Function Call Node
    The Particle Call Node invokes a remote function on a device within Particle.
  • SendGrid Node
    The SendGrid Node sends emails through a given SendGrid account.
  • Slack Node
    The Slack Node sends messages to a given channel within a Slack workspace.
  • SMS Node
    The SMS Node sends an SMS message through Losant's provided SMS delivery service.
  • Tweet Node
    The Tweet Node posts a tweet using the provided Twitter application and account.
  • Twilio Node
    The Twilio Node sends SMS messages using the configured Twilio account.
  • UDP Send Node
    The UDP Send Node sends a UDP datagram to a given address and port.
  • Webhook: Reply Node
    The Webhook: Reply Node sends a response to an HTTP request received by a Losant Webhook.
  • WebSocket Message Node
    The WebSocket Message Node publishes a message to a WebSocket integration.
  • WhatsApp Node
    The WhatsApp Node allows you to send messages using your WhatsApp Business account.
  • Workflow Trigger Node
    The Workflow Trigger Node invokes another workflow execution with a custom payload.
